What is the proper video source to watch cable on a Westinghouse Ltv27W7
  • 3,904 Answers
If you are going for the best and easiest than I would choose HDMI. Next, which would be just as good, would be the component (red green blue). The next step down, if available, is the S video. You most likely do not have that as an option. Next would be composite which is the yellow input and finally would be straight coax into the set. Coax, if it is digital coax, would give you a nice picture as well.
Posted on Apr 02, 2014
3 Suggested Answers
  • 1121 Answers
SOURCE: westinghouse LTV27w7. I turn it on and it almost
there is a PSU output or Inverter Board defective. Needs to be checked
Posted on Dec 22, 2009
  • 1738 Answers
SOURCE: Buzzing sound when using HDTV input on
It is your cable box, contact your cable company.
Posted on Dec 29, 2009
I have a Westinghouse LCD tv and i lost the remote but in trying to run auto scan and it keeps telling me to press enter but I don't know how to
WESTINGHOUSE LCD-TV USER MANUAL Pdf Download.
www.manualslib.com > ... > Flat Panel TV > LCD-T
Westinghouse Digital 27'' Wide-Format LCD - TV User's Manual. ... the analog cable or TV antenna wire (not included) directly to this LCD-TV antenna input. ... a list of video sources using the SOURCE button located on top of the LCD-TV.
images for Westinghouse LCD tv enter button location
Sep 28, 2015 | Westinghouse Televison & Video
How do i get my westinghouse to recieve signal it shows on the tv no signal and on the box it says that the tv does have a signal
Make sure you have the TV tuned to the proper source.
My TV has multiple input sources ranging from the cable box to various AV and gaming equipment and I must select the right input source in order for the TV to receive a signal.
On my controller, there is a button at the top for selecting the input source. I can cycle through all sources by pressing that button. If you're using a programmable universal controller, that function may not be programmed into the universal controller so you may need to use the original controller that came with the TV.
If, after you've cycled through all of your available sources and still get no signal, check and see if a wire has come loose between your cable box and TV, either at the cable box end or the TV end.
Hope this helps.
Sep 09, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My tv when powered on, only show the westinghouse logo and then the screen turn black in about 3/4 seconds
The TV is not receiving a video signal. It is probably the cable you are connecting the tv to the source. If you are using an adapter, don't. Buy a proper cable.
Mar 31, 2014 | Westinghouse 32" Flat Panel LCD HDTV
2004 jvc 56in projection tv, has sound but no picture
Hello
Change the channel to ensure the problem isn't with the current station broadcast. Check the channel at a later time to see if the broadcast problem is resolved.
The type of programming you are trying to watch determines the proper input source. Press the "Input" button on the remote control to change to the proper input source. For example, if the source is a cable or satellite service, press the "Input" button until "TV" mode is selected. A component device, such as a DVD player, will operate on a different input source, such as "Video-1."
Check the coaxial cable, which connects your television broadcast service provider to your television. You need to securely connect the coaxial cable to the "ATSC/Digital Cable In" jack on the back of the television, and the other end to the wall jack. If the cable appears damaged, replace it with a new cable.
If you are using a component device as the source of your programming, ensure the component cables are plugged into the "Video Input" and "Audio Input" jacks on the back of the television or that the S-Video cable is plugged into the "S-Video Input" jack on the back of the television. Connect the other end of the cables to the "Video Output" and "Audio Output" jacks or "S-Video Output" jack on the component device.
Oct 02, 2010 | JVC AV-56WP84 56" Rear Projection...
I'm only getting analog sound when tv is on, optical cable is hooked up properly, maybe a bad cable?
Name the TV model and define the routing of said optical audio cable.
Digital audio is rarely originated at the TV but it usually comes conveniently from the source you're watching on it. Try routing the digital audio directly from the source to the Yamaha and bypass any limitations imposed by marginal TV electronics.
May 20, 2010 | Yamaha HTR-5730 Receiver
Westinghouse LTV27w7. I turn it on and it almost
Dec 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Get my PIP to work!!!!!!!
The "Picture in Picture" function will only work with a "digital" source like hdmi or dvi input. It will not work with an s-video or vga input source.
Oct 31, 2009 | Westinghouse W32701 27 in. LCD HDTV
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Stuck on a video mode
Some TV's disable inputs if there is no signal. I suggest confirming cables are connected properly, and accessing the system menu, and perform an autoscan for channels
Apr 27, 2009 | Initial HDTV-320 32 in. LCD TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
