I get no picture after scan How do i get channels on my ltv-27w7
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Check and replace its main system control memory IC. It is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Posted on Apr 02, 2014
3 Suggested Answers
  • 1348 Answers
SOURCE: My Westinghouse LTV-27w7 Black out
the high voltage circuit is shutting down.
the two most common faults are the flyback transformer,and an overvoltage condition from a blown regulator.
both are repairs where the tv is thrown out.
the days of the loose wire are gone.
Posted on Aug 22, 2009
jdvillanueva
  • 2098 Answers
SOURCE: when i turn on my
This is an indication of out-of-regulation condition on the power supply section. The caused of this symptoms is the leaky/dried electrolytic filter capacitor in the power supply section. It will dropped the supply voltage and sometimes it produced an overload to the chopper transformer and produces that kind of symptoms. It needs a little warm-up to make itself stable but the symptoms will get worst, time will come the unit will not power up at all.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can easily be identified while dried capacitor has no physical indication of fault. You must have a capacitor checker to determine its condition. If it is not available, you may replaced all electrolytic capacitor in the output of the power supply section. It has a capacitance and working voltage which is labelled on its body itself. Replace it with same rating. Upon installing a new capacitor, ensure that the polarity (positive and negative side) must be at its location to avoid further damaged. It will not cost you much because each capacitor cost only less than a dollar. Also if you are going to DIY, you will save $200-$300 for service fee of the technician.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified technician to isolate the problem.
Check also if your unit is still under warranty/warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 18, 2011
Why doesn't it stay on channel?
Gustav, Try factory reset, to get to the Setup Wizard. With the TV on press the menu button on your remote. While the menu is displayed press the 0 button four times. This should bring up a new menu with factory reset as an option.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.hdtvsolutions.com/pdf/27w7_32w6_37w2uMan.pdf
Westinghouse LTV 32w6 User Manual
How do you factory reset Westinghouse lcd tv AskReddit
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/678671-new-offical-westinghouse-ltv-27w7-ltv-32w6-ltv-37w2-thread-87.html
Mar 12, 2016 | Westinghouse LTV32W6HD 32 in. LCD...
When watching HD (i.e. channel 7.1) the screen goes blank and all controls (remote and on tv) are unresponsive. the sound works. (white-westinghouse ltv-27w7-HD)
then ur picture alone is getting affected,... this can be due to your hotizontal or vertical ICs that is the problem
Apr 30, 2008 | Televison & Video
27WXXX. Where can I get a manual?
Instructions for RMT-05 probably are included in the TV manual.
Aug 29, 2015 | Westinghouse RMT-05 TV Remote Control for...
How can i get service manual for westinghouse tv model 42B 8000 series 7
Try to go this link http://www.retrevo.com/support/Westinghouse-LTV-27w7-HD-TVs-manual/id/278dj978/t/2/ it might help
Jun 25, 2011 | Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse LTV-27w7 HD 7 -- after a storm - the tv was the only thing affected in the house. The light comes on when the power is turned on, yet nothing else comes on - no picture and it will not turn...
same thing happened to my lcd. I had it checked out and the specialist said it needs a new motherboard. You can order one @ shopjimmy.com for under $200. Just swap it out. Hope this helps
Aug 14, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
I was watching a video and then the screen went balck and said "no signal". I pressed some buttons on the remote and it looks like I set it back to factory settings and now I have no channels. I have tried...
hi, if you see a message "No signal" try to check if your on the right input. Use your remote control to find the right input, youll see an INPUT or SOURCE button use that to find the right input. hope this helps, goodluck.
Jun 11, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
RE-TUNED Mikomi LCD15796BF Freeview tv on 30
Buy a digital antena or have roof antena,get better receptions and stable Hz.Rescan when get better signal should get it back an it stable's.
Sep 30, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Aug 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
