Question about Nordic Track C1800 Treadmill
Nordic track C1800i
My nordictrack c1800i treadmill slips when reached over 3.5 mph- 4mph
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Posted on Jan 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
SOURCE: nordic track c2000 belt slips
I would try to tighten the rear roller a little and see if that helps.
1 start the treadmill and operate it at 1.5 mph then hild onto the handle bar and plant your foot against the belt at the front. If it slips tighten the roller 1/4 turn on each side. Then try the slip test again and repeat the process, do not tighten it too tight that will cause the belt to fold in teh center and be ruined. You May quite possible need a new belt. Take the belt lose and look at the underside and see if it;s glazed (shinny) or has pieces missing under the center of the belt, if so replace the belt and also clean the rollers front and rear, also flip the deck over it shoudl have a wax coating on the other side if that hasn;'t already been done.
Posted on Oct 23, 2011
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
Track needs to be tightend on my nortic track c 1800s
Step 1:
please see the video and diagram attached. God bless you
Step 2:
mkwrinri3haaaaaelftksuqmcc
Step 3:
h8oly96lhb9tqaaaabjru5erkjggg==
Jan 04, 2013 | Nordic Track NordicTrack C 1800S Treadmill...
My Nordic Track A 2050 is slipping. At first I noticed it slip from time to time in my 45 minute workout, but at the end, it was like I was on ice. I love this treadmill, is there a way to fix it?
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Dec 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a nordictrack a2250 when run on it the belt slips i need to tighten the belt
If your treadmill has had a lot of use, the belt has probably stretched and needs replacing. You can order a new one at Treadmill Parts
Nov 07, 2010 | Nordic Track NordicTrack Treadmill, A2550
The Nordic Track machine's controls seem to be stuck. If I press any button other than "3 mph", it fails to respond and nothing happens. However, when I press the 3 mph button, it will only stay at the 3...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Jul 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
Feb 27, 2010 | Nordic Track NordicTrack Treadmill, A2550
Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Feb 05, 2010 | NordicTrack Exercise & Fitness
Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Feb 02, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track C1800 Treadmill Logo
52 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
