Question about Fasco York 024-34558-000 Furnace Draft Inducer Blower A225
Problem with draft inducer blower fasco A225
The draft inducer blower fasco A225 on luxaire furnace started making a loud grinding noise...found that some of the blades had broken off inside...replaced t with the same make and model and seems to be running fine now but the motor on the new blower seems to be getting quite hot!! is this normal?? I have good exhaust so there don't seem to be a blockage...can something else be causing the motor to overheat or is it normal for it to be hot??
  • jason hrelja
    jason hrelja Apr 02, 2014
    I may have found the answer to my issue in the owners manual for the blower...it says be aware that the surface of the motor may be very hot when running under normal load conditions or even when its not operational...touching a motor frame may cause severe burns.
5 Suggested Answers
  • 252 Answers
SOURCE: Armstrong sx 90 draft inducer is getting water in it.
nope, condensate drain clogged
Posted on Nov 17, 2009
heatman101
  • 43501 Answers
SOURCE: Please help! Our draft inducer on our gas water
You are OKAY!!!
If the inducer connot run the gas valve will not turn on.
You will be fine till morning the way you are.
Just be sitting down when they tell you the price of a new inducer...
Heatman101
Posted on Jan 20, 2010
  • 9 Answers
SOURCE: The draft inducer blower is not functioning is
yeah long as he got abit about him
Posted on Mar 06, 2010
  • 760 Answers
SOURCE: My hot water heater exhaust blower seems to run
Your blower should run from before the heater lights until after it has shut off. Even if you're not using water, it will cool, and the heater will have to light to maintain temperature.
Posted on Oct 16, 2010
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
I removed my Fasco 7021-11577S when the bearings went bad and ordered the A225 OEM replacement. I notice that when mounted this new draft inducer it whistles really loud .Is the hole in the back of the...
There should be a gasket between the mounting flange of the inducer motor and the furnace. If you do not have that you can use a small bead of blue or red silicone caulking to seal it. Hope this helps you. Thanks
Mar 29, 2011 | York Furnace Draft Inducer Blower Fasco #...
When the furnace comes on after recovering from low thermostat setting, we can hear a loud noise, something akin to a wooden bead that's being blown around inside the unit. Once temperature is reached, the...
Could be correct, or you may have something in your fan that either fell into or crawled into your fan through the exahust duct.Since you have a service contract, have they actually been out to look at it or did they tell you that on the phone. It might be worth removing the fan and clear any forign matter. The problem is the labor to do that would be the same as to replace it. What does your service contract cover??
Feb 24, 2010 | Omega Trane Furnace Draft Inducer Blower...
90 + gas furnace. inducer full of water
need help with gas furnace put in new presure switch and it worked for a while now i have to blow into it to get it to turn on ignitor .
Dec 05, 2009 | York Furnace Draft Inducer Blower Fasco #...
Draft inducer blower going bad
I agree close enough. Only slightly slower. If it fits mechanically , useit.
Jan 17, 2009 | Omega Trane Furnace Draft Inducer Blower...
Fasco York 024-34558-000 Furnace Draft Inducer Blower A225 Logo
94 people viewed this question
Top Fasco Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Fasco Garden Expert? Answer questions, earn points and help others
