Question about KitchenAid 5-speed Blender With Glass Blender Jar Ksb565er
Blender glass jar is leaking at base
Glass jar is leaking at base
  • KitchenAid Master
  • 1,316 Answers
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Posted on Jul 23, 2014
  • 5 Answers
SOURCE: my blender seems to spin without the glass blender
your blade assembly is corroded. take it off, and using a rag, grab the blades. using another rag, grab the other end (probably rubber) and turn CLOCKWISE - it's threaded reverse, so you have to turn to the right to loosen, not the left like usual. I had to clean out the rod that connects to the blades - it was all nasty and corroded. I cleaned it with my Dremel and regreased with a tube of grease I keep in the garage, cleaned all other parts with some Dawn, dried well, reassembled, and works almost like new. I'm guessing I ran it too long without pulsing the motor and the heat corroded the rod that's connected to the blades. OR you can buy a replacement blade unit for about $10 online on a blender parts site
Posted on Jan 15, 2010
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
SOURCE: Need new glass container for kitchenaid blender.
They are usually in stock here:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Posted on Jan 24, 2010
  • 1739 Answers
SOURCE: We own a kitchen aide
The Instruction & Recipe booklet for the Kitchen Aid KSB550, KSB560, KSB570, KSB580 5-speed Blender can be found here:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209709225.pdf
There is no infomration to suggest that the blender blade could be removed for replacement of a seal
On page 27 of the pdf (page 24 if printed) there is contact information for ordering replacement parts. You might ask if the blade assemly can be ordered and replaced separtely but I believe you must replace trhe blender jar and blade unit as one piece.
Posted on Mar 18, 2011
SOURCE: My 5 speed KSBS kitchenaid
Have a look at the pictures here.
I think you are describing the blade unit's gasket being stuck. This can happen over time and especially if bits of food get stuck and harden. Try soaking for a long time in warm soapy water then keeping applying pressure until the seal between the gasket and jar gives.
Posted on May 07, 2011
My blender leaks at the base of the carafe
A couple of things you can check.
Unscrew the glass jar from the bottom.
Check to see if the grey seal is between the metal blade assembly and the glass jar. I had this issue and it turned out to be that a friend had reassembled the blender jar parts after taking it apart to clean it.
Mar 07, 2014 | Oster 6700 Work Top Blender
Starbucks Glass jar replacement for blender
I bought an Oster 6 cup glass and it works perfectly on the Starbucks Barista blender. It has to be the 6 cup NOT the 5 cup or the blade mechanism won't fit. the 6 cup screws right on your old blade base and it was $10 new on Ebay including free shipping.
Feb 20, 2014 | Braun MX2050 Blender Powermax Replacement...
Replacement glass jar for 2003 Starbucks blender
Feb 02, 2013 | Braun MX2050 Blender Powermax Replacement...
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
Can not remove base from blender model BL5500SC
leave the blender jar on the blender. with one hand grab the glass jar handle with the other hand hold the base of the blender. then twist or push the handle counterclockwise to free it up so you can completely remove it from the blade
May 19, 2012 | Blenders
My wife broke jar.I am loking for replacement
I have a replacement glass jar for you. My base broke so I am willing to sell the glass jar part. please email me at mimitascoe@gmail.com
Mar 15, 2011 | Juicelady JL600 Professional Work Top...
The plastic threaded base for the jar on this blender haier 2 speed / glass jar is cracked - is part available ? thanks
The base ring part probably is available, however, you MIGHT want to try gluing it with the BLACK ABS plumbing glue. It is surprizingly strong if you have clean break
Sep 16, 2009 | Haier HB500 2-Speed Blender
Need Jar
purchase from any of the below links>>
http://buyitnow64.stores.yahoo.net/habeplbljar.html
http://cgi.ebay.com/KENMORE-BLENDER-GLASS-JAR-WHITE--BQ_W0QQitemZ250368347086QQcmdZViewItem
http://cgi.ebay.com/KENMORE-BLENDER-GLASS-JAR-BLACK-BQ_W0QQitemZ280310226122QQcmdZViewItem
please rate this solution.
Thanks for using FixYa.
Feb 09, 2009 | Kenmore KMB048 Work Top Blender
KitchenAid 5-speed Blender With Glass Blender Jar Ksb565er Logo
751 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
