Question about Kenmore Refrigerators
Water makes a hammer noise
Makes water hammer noise
2 Suggested Answers
  • 189 Answers
SOURCE: Water hammer makes a loud vibrating noise when filling
Hey- most hammer is removed by simply replacing the water valve. Have solved this way many times. Exceptions required spring suppressors on lines to faucets. Valves run about 40-60$ and are easy to install. Let me know if this info helps- have more if needed- Thanks- Ed
Posted on May 13, 2010
When using shower basement pipes start clanging and Rattle and make a horrible noise some say it's water hammer some say I need to replace the flap in my toilet bowl any suggestions
Debbie, probably water hammer, but your pipes may not be supported/attached properly. Have a good plumber or a knowledgeable friend take a look to see if pipes hang loosely and can be attached more securely. If pipes are secure and supported properly and noise is still there a water hammer will have to be installed. Check the attached links,instruction and guides they may enable you to cure the noise from pipes on your own. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Noisy Water Pipe Hammering Tips Plumbing Maintenance and Repairs
How to Quiet Noisy Water Pipes
How To Fix Pipes
Water hammer noise and the cures
Apr 09, 2016 | Home
How to get rid of water pipe noise at home
This usually occurs with high water pressures.
It may help by installing a water reducing valve at the water meter.
When a dish washer or washing machine turns on and off the water you will get a water hammer noise. The pipe fixings have come loose over time and the pipe bangs against the fixings.
You can reduce this noise by installing a water hammer device on the all the taps and then connecting the hoses from the dishwasher and washing machines to the water hammer devices.
I suggest you check out the best options with a plumber.
Apr 04, 2013 | Dane-Elec DaneElec 4GB USB Drive Copper...
A few seconds after flushing our toilet, it begins to make noises like a freight train through the pipes.
Could be a water hammer affect causing noise in water pipes, if so you can get a water hammer arrestor to go in line to help out. Also check the ball **** valve inside tank it could be bad or partly blocke dcausing noise in line.
Jul 30, 2011 | Home
Noisey waterpipes what is this?
It is referred to as "water hammer" It means that there is air trapped in the pipes
and causes chattering (it will also rattle loose pipes in walls). Best option is to
have a "pressure tank" installed at the water heater to reduce this. Hope this is helpful.
May 30, 2011 | Plumbing
I installed new moen muirfield sink. It worked just great. Water flow just smooth. Then few hours later, it started making thumping sounds but when I use the spray, it stopped. But when stopping using...
That is called 'water hammer' and is usually coming from an old fashioned stop valve. The stem with the washer is bouncing up and down.
http://www.moen.ca/kitchen-bar/faucets/kitchen/muirfield/_/N-6a2Z1z141ulZ1z141o8 ]
Water hammer - Wikipedia
https://en.wikipedia.org/wiki/Water_hammer
A water hammer commonly occurs when a valve closes suddenly at an end of a pipeline system, and a pressure wave propagates in the pipe. It is also called hydraulic shock. This pressure wave can cause major problems, from noise and vibration to pipe collapse. ‎Hydraulic ram · ‎Nikolay Yegorovich Zhukovsky · ‎Surge tank
How To Stop Water Hammer - How To Fix Pipes ' HowStuffWorks
home.howstuffworks.com > ... > Home Improvement > Home DIY > Plumbing Water hammer is a specific plumbing noise, not a generic name for pipe clatter. It occurs when you shut off the water suddenly and the fast-moving water rushing through the pipe is brought to a quick halt, creating a sort of shock wave and a hammering noise.
Waterhammer - YouTube
? 2:34
https://www.youtube.com/watch?v=f9LY0-WP9Go Nov 27, 2013 - Uploaded by IAHR Media Library
From Effects of Fluid Compressibility - (Hunter Rouse) Courtesy of Dr Marian Muste, IIHR - Hydroscience ...
What is water hammer and how to prevent it - PlumbingMart.com
www.plumbingmart.com/water-hammer-information.html Find Water Hammer - PlumbingMart makes it easy to do plumbing and even misspelled pluming and plumming.
What is Water Hammer? Plumbing Tips on How to Solve It - The Balance
https://www.thebalance.com > ... > Construction > Materials > Mechanical Systems Mar 4, 2017 - Water hammer is a common plumbing issue where water changes direction suddenly. Use any of these 4 options to solve water hammer issues.
water hammer Google Search
Jul 11, 2017 | Moen 87530 Touch Control Single Handle...
May 13, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Hot water: Pipes make a banging noise when turned on full force.
Hi, That banging is sometimes called a water hammer. It is made when the water hits an elbow in the piping with a force and bangs into the pipe itself. It is more likely to occur in a long run of pipe. This can be reduced or eliminated by installing an empty tube verticle in the piping near where the hammer is occuring. This tube can be found at most building supply stores. The tube is a pocket of air that acts to absorbe the extra pressure from the piping and stops it from hammering.
May 05, 2010 | Delta 2 Handle Lavatory With Metal Pop Up...
Loud hammering noise with vibration on piper when the cistern fil
You're experiencing "water hammering" it's solvable too.
You can buy anti-hammer add-ons which you can put under a nearby sink, or even on an outside hose bib. This will give the water pipes an air "shock absorber"... since air compresses it cushions the abrupt changes in the pressure where as if it's just water, it'll slam and hammer and vibrate...
Try an anti hammer device added to you supply... you should be able to add it with out too much tearout.
K
Jun 18, 2009 | Caroma 270W-RF Reflection Round Front...
Water pipes making noise trying to locate
Good luck! If it is "water hammer" and you already have water hammer arrestors (dead end sections of pipe) the the arrestors MUST be water logged - when you drained the system how long did you leave it open after empty? Sometimes it can take a little while for the arrestors to drain after reaching "empty". The proper solution is to get the arrestors working or add more - not trying to find the noise and dampening or muffling it (the arrestors do more than stop banging!)
May 03, 2009 | Heating & Cooling
Clunking noise in sink
You are describing a problem known as water hammer. This will ultimately cause damage somewhere in your plumbing system so it should be addressed. If you are handy you can install an air chamber near the sink. If you want more information let me know. good luck.
Jan 17, 2009 | Home
Refrigerators Logo
11 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
