Question about Global TC2203-DU Hydraulic Door Closer Size 3 Spring, Duronotic
Need a steel arm replacement part
The arm of the door closer keeps getting stuck open it hyper extends and then gets caught on the door itself. We have replace just the arm and now the entire mechanism and the same result. Someone mentioned it is due to the arm being made from aluminum.
    New Friend:
  • 87 Answers
Adjust the backcheck. The pressure should increase as you get closer to the furthest point you want the door opened. You might consider a door stop as well.
Posted on Jun 25, 2014
Are gate closers really effective & how it works?
Gate closer is a device, which consist of steel spring in a spiral shape fix on the door that close the door automatically without any human being intervention or electricity. http://www.gateshut.net/about-gate-closer.html
Jul 24, 2013 | Rixson Exterior Gate Closer With Sliding...
What is Spring Gate Closer and How it Close the door automatically?
It consist of hard steel or aluminum in spring shape, which force the gate to shut it close the door automatically without any electricity or heavy internal mechanism.http://www.gateshut.net/
Jun 07, 2013 | Rixson Exterior Gate Closer With Sliding...
Is Spring Gate Closer use any internal mechanism or hydraulic system to close the door?
I think spring gate closer close the door on it's own. It's consist of high grade steel spring, which close the door automatically without any heavy internal mechanism,hydraulic or electricity.http://www.gateshut.net/
May 29, 2013 | Cars & Trucks
Upper thread keeps breaking on Brother ULT 2001
the tread gets stuck on in the thread take up arm, there is a joint ware the arm is rived to gather, the thread get caught between arm and the rived sheet steel . . take little silicon gasket and fill in the joint so thr thread can't get stuck where its rived
Jan 13, 2012 | Brother ULT2001
My driver side windshield wiper gear is stripped out allowing the wiper to go were it wishes. It either travels to far and ends up getting stuck on the driver door or it goes to far down and ends up...
Knowing the make and model of your vehicle would help immensely. From your description and my experience, I would say it's not a gear, but the wiper arm itself. Where the arm mounts to the wiper transmission (aka motor), there will be a plastic or sometimes metal cover, gently pull or pry upward on the edge of it to expose the nut that keeps it in place. Remove this nut and then the arm, and inspect the 'teeth' or splines inside the hole on the arm, and on the wiper transmission, where the arm mounts. Most often the arms are made of aluminum, and the transmission is of steel, so the arm will strip first. Usually the arm can be replaced (try a junkyard for a low cost replacement) without much effort, and a few basic hand tools. Also be sure to clean any residual material from the wiper transmission where the arm mounts prior to installation, a piece of steel wool or brillo pad usually works best. I hope this helps, and good luck.
Jan 19, 2011 | Kia Sportage Cars & Trucks
Cd tray is stuck in open position on my HP computer
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
May 12, 2009 | HP Computers & Internet
Car keeps arming when i have my door open
techs finally discovered that the door latches inside were shorting out hence not reading that they were opened...so they replaced those.
Jan 09, 2009 | 2003 Volkswagen Passat
Soap dispenser doesn't open
I have had the same problem in the past. Usually I found that something of large size was sitting in the corner just in front of where the soap door opens. The door tries to open, hits this item (in my case a cutting board) and can't open completely. Try keeping only short items in this corner and see if it helps. Good luck!
Sep 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Global TC2203-DU Hydraulic Door Closer Size 3 Spring, Duronotic Logo
106 people viewed this question
Top Global Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Global Hardware and Accessory Expert? Answer questions, earn points and help others
