Question about Mitsubishi Televison & Video
I changed my bulb to weeks ago and now it wont fire have sound and no picture i have a wd 73c-10
Why is my wd73c-10 lamp no coming on I replaced it about two weeks ago and now it doing it again
    Scholar:
  • 195 Answers
Use a good original or a Phillips bulb--do NOT use a Neolux bulb !!
Posted on May 08, 2014
ctf1800
  • 4402 Answers
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Posted on Dec 08, 2007
  • 178 Answers
SOURCE: no display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Posted on Sep 02, 2009
  • 668 Answers
SOURCE: mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Posted on Oct 26, 2009
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
SOURCE: Mitsubishi WD-62531 Replaced lamp 2 weeks ago.
i have a mitsubishi wd-62531 modle i replaced the buib with a phillips bulb wich the salesman says that my old bulb crosses over too now the picture seems to be to dark....could the bulb be not bight enough
Posted on May 11, 2011
Installed new lamp but her static sounds wd-73733 and still no picture
I would venture to guess the bulb figment is your issue and the electrical sound is most likely arching (very bad). The cheap replacements won't last. I bought a sylvania build and matched the model number with the one from inside the old bulb housing. Changing out the bulb from the casing is really easy so just return the one you bought and buy the corresponding bul without the case.
Jun 26, 2014 | Mitsubishi WD-73733 73" HDTV
Did you use a generic bulb or a "Neolux" lamp--Mits does NOT like those. Use a Phillips bulb or an original NON neoloux one.
Apr 01, 2014 | Mitsubishi Televison & Video
My TV will not turn on. I just replaced the tv lamp 2 weeks ago. Help!!
did you use original Mits Lamp or a generic?? most mits DLP tvs wont run long or at all with generic lamps
Sep 30, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
My model is WD 62525 have sound but no picture. For serveral weeks the tv would come on with blinking yellow light and then red lamp light would come on. We would unplug and wait a couple minutes and plug...
Hi , make sure you put the cover back on so it can press the switch to let the tv know door has been shut and will allow to light bulb.Also when putting a new bulb in the ballast, which is the board that powers the lamp, sometimes its not able to provide enough power to light it up because it was used to provide a lesser voltage on the old lamp.Make sure you reset the lamp timer I dont know the exact code for it but u can search it on your manual.Hve a blessed weekend!
Apr 22, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp does not get picture
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
