Question about Pride Health & Beauty
Scooter How do I know that the motor malfunction
  • Pride Master
  • 1,271 Answers
Hi, mainly by measuring the resistance, the two wires coming from the brake , resistance is about 0.4 to 1.0 ohm, any more than that could be a issue, check the brushes, very important..
Regards
Rob.
www.facebook.com/gewizrepairs
Posted on May 24, 2014
  • Robin Hill
    Robin Hill May 24, 2014
    hi, mainly by measuring the resistance, the two wires coming from the motor , resistance is about 0.4 to 1.0 ohm, any more than that could be a issue, check the brushes, very important..
    Regards
    Rob.
We need to know how to rewire a celebrity mk 1 motor and brake as the wires have been cut and dont know how the wires go together thanks
should be someone listed to service and repair that model in your
local area
contact a local supplier /seller of new and used scooters
Pride Products
Contact us
Sep 02, 2016 | Health & Beauty
Have no spark to plug found a 2 wire clip with the same colors at the battery area that is not connected to anything. dont know where to connect trouble finding manuals or video
My scooter has no spark how to fix. gy6 chinese ... - YouTube
? 2:29
https://www.youtube.com/watch?v=UU4S0Ov9q4c
Aug 24, 2012 - Uploaded by Rolling Wrench
Purchase our "NO SPARK KIT" click the link below: ... Myscooter has no spark how to fix. gy6 chinese scooter 139qmb qmb139 50cc 150cc .... i have a 2003 panterra fusion scooter with a 49cc motor,i just purchased a new cdi box,new coil wire and a new stator and ... Put gas in it tried it again nothing.Missing: rto
RTO 150cc scooter no spark Questions & Answers - Fixya
www.fixya.com/tags/150cc_scooter_no_spark/browse/rto
Ask your RTO 150cc scooter no spark questions. Get free help, advice & support from top RTO experts. ... no spark. Ad. Question about Gas Motor Scooter 150cc.
Nov 29, 2015 | RTO 150cc Gas Motor Scooter
How do I fix my ezip 450 electric scooter
Your battery may have gone bad. It may have enough juice to turn on the lights but not enough to run the motor. Try connecting the battery directly to the motor terminals. If it runs ok them you may have a bad speed controller.
Sep 20, 2014 | Health & Beauty
Brake comes on
Hi do u know the make - model ....cheers
Apr 12, 2014 | Electric Mobility 4 Wheel Power Electric...
8 FLASHES
Hi, this is the official advice given, please let me know how you get on
8 Motor Volts The motor is not connected to the controller, or there is a short-circuit in the
motor connection. The scooter does not drive.
• The motor brushes may have lost connection. Turn the wheels of the
scooter to reconnect the motor brushes, and then turn the controller off
and on. If this happens often, the motors may be faulty.
• Check that the motor cables are not loose or damaged.
Regards
Rob
www.gewizrepairs.co.uk
Feb 28, 2014 | Invacare Atm Take Along Chair - Red
Pride mobility scooter died after bogging down and tripping the fuse repeaedly
iT sounds to me like you have one or more shorted windings on the armature of your drive motor which is apart of the trans-axle assembly. TO BE SURE remove the entire trans-axle module. I have a Rascal 600t all i have to do to remove my trans-axle is to remove to quick pins and my entire trans-axle assembly comes away from the scooter. Take the entire assembly down to your local motor repair shop that can rewind motors. Thay will check out the motor, take it apart and clean all the carbon dust from the brushes that gets all over the interior of the motor, doesn't do the motor bearing any good. Rewinding a motor isn't inexpensive costing $200 and up depending on the size and complexity of the motor. But the scooter trans-axle cost is astoundingly high at $1,500 and up. They say they are sealed unit and that they can not be repaired. In reality trans-axles are quite simple to repair and easily repaired. The only difficult thing are the scooter companies that will not come across with the parts and info we need in order for us to keep our scooters in good repair. So ii'd take the trans-axle down to the motor shop. They don't charge anything to check it out. When they do maintenance you will know its working right. When troubleshooting problem with scooter you eliminate half the machine when you eliminate the trans-axle. Get back to me once you've checked it out
Jul 12, 2012 | Pride Mobility Products Health & Beauty
My batterys and charger are fine. but when i leave to go down the street it goes dead and the motor is hot. dont know what to do or where to take it and my money is stretched to its limit. can u help
Bonton you don't say if you are getting flashes on your console when the scooter stops. Did you purchase the scooter or did Medicare? If Medicare paid for it they will pay for most of the repair cost Since your scooter has an electric motor it will get hot when using it . How old is the scooter? If your batteries are good then you could be in need of brushes for the motor which are cheap considering the cost of a motor. you can call Repair Xpress @ 1-877-581-3733 to see if they have a tech in your area that can check the scooter for you and the cost should be reasonable. I hope this helps you. Let me know
Sep 12, 2010 | RTO IMC-Heartway NOMAD3 Nomad 3-Wheel...
Pride sonic scooter won't turn on. the battery is charged and the motor is functional. Appears to be an electrical switch. any suggestions?
How do you know that the motor is functional? Have you load tested the batteries. If the batteries are bad usually they will still take a surface charge and appear to be fully charged.
Jul 08, 2009 | Pride Sonic 3 Wheel Portable Scooter
Schwin scooter not running properly
If the battery is old its likely that it needs to be replaced. Also, if batteries sit in the cold in the winter or are exposed to high heat they can be damaged. Try checking out http://www.batteryinternational.com/electric-scooter-batteries.html for a scooter replacement battery.
Jun 09, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
May 16, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
42 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
