Question about Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo
Bulb how do i replace the bulb
  • Philips Master
  • 3,904 Answers
Lay the set face down on a packing blanket or something like that. remove the foot that it stands on and then the back of the monitor. There will be around 12 screws holding it on. Remove it carefully as there are always control boards attached in the molding. Locate the bulb, replace and put back together.
Posted on Apr 02, 2014
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Bertazzoni hood replace bulb
First remove cover to access the bulb, pull bulb straight down being careful not to break it. to replace w/new bulb, remove bulb from package, be sure to use a cloth or some type of glove so as not to get oils from your fingers on the new bulb as this will create a hot spot on the new bulb and shorten the life of the bulb. Install the new bulb by inserting into the fixture by gently pushing the bulb into socket.
Hope this helps
Apr 19, 2014 | Bertazzoni K30 PRO X 30" Kitchen Hood
Need a diagram on how to replace light bulb in clock in EL Falcon dash.
To replace the clock light bulb on 2001 Honda Accord, you will need:
  • Screwdriver
  • Replacement bulb
  1. Remove the clock assembly in the 2001 Honda accord. Pry the clock assembly off by wedging a flathead screwdriver into the edge and prying off the cover. Work your way around until it comes off.
  2. Remove the old bulb by pulling it out of the socket. Dispose of the bulb.
  3. Replace the bulb with an equivalent bulb. Simply push the bulb into the slot. Be sure to take the bulb with you when you purchase a new bulb so you get the exact bulb. Purchase a bulb with the same voltage. Although a bulb with different voltage may work, it can burn out more quickly.
  4. Replace the clock assembly. Line up the clock assembly over the bulb and press firmly on both edges to attach it back to the 2001 Honda Accord dash.
Tip:
  • Place masking tape on the edges of the dash around the clock assembly to protect your dash while you are removing the assembly with the screwdriver. Remove the masking tape when you are finished replacing the clock light bulb on your 2001 Honda Accord.
Jul 05, 2011 | Falcon 4420
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    How do I open the top of the projector to replace the light bulb?
    Hi, Follow :- http://www.wikihow.com/Replace-a-Projector-Lamp There is a Video as well on the same page.If you wish to Purchase the Bulb, you could consider :- http://www.partstore.com/minisites/projectorLamps/HowToReplaceProjectorLamps.aspx Let me know, if needed further assistance, Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
    Feb 10, 2010 | Televison & Video
    How to replace headlight bulbs. How to access
    Locate where the wires go into the headlight on the engine side. You should be able to find the locking collar. Turn it counter clockwise and remove the bulb at this point you should just have to unplug the old bulb and reverse the process to install the new bulb.
    Jan 25, 2010 | Mercury Mountaineer Cars & Trucks
    1994 Acura vigor gear indicator light won't light D4. All other gear indicator lights work. Happened after replacing two dash lights
    WHILE REPLACEING OTHER DASH LIGHT BULBS THE JOSTLING JUST BURNT OUT THE ALREADY CLOSE TO FAILING D4 BULB.
    Jun 14, 2009 | 1992 Acura Vigor
    Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo Logo
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
