Question about Cub Cadet Riding Lawn Garden Zero Turn Tractor
Replaced stater trided to start shorted stator out
2006 mod. 53aa5b7p710
    Problem Solver:
  • 29 Answers
That should not have happened unless some wires got crossed somewhere.. In most cases like this its a simple mistake of putting the battery terminals on the wrong sides.. Dis you have the wires loose from the solenoid? I am not exactly sure what your question is but I will be more than happy to help you in any way I can, I can start with the wiring breakdown if you need it..Best of luck..
Posted on Apr 13, 2014
How do i fix a stater for a atv
Usually you need to replace the regulator/rectifier & stator at the same time. Why? Your stator puts out 220-240 v ac current. enough to power an electric dryer. That is turned into about 15v dc current for the battery. What usually happens in ATV's is the electrical connectors are lousy and fail. This burns out one or both units. Motor sport mechanics are well aware of this so to avoid retesting and chasing shorts that come and go they replace the whole thing so they don't have people coming back for warranty work. You can find after market parts online for much less than you can buy at motor sports retailers. A few hundred vs a thousand plus. Don't forget the gasket under the housing when you get at the stator. You can't avoid the dealer price on the gasket.
Sep 30, 2015 | ATVs
How do you test the stater on a 1990flhs
Hi Anonymous, you need a multi meter, first check for grounds by unplugging regulator from stator, set the meter to ohms and connect one lead to ground and the other to a stator pin, reading should be infinity. Next connect both leads to stator pins reading should be 0.2 to 0.4 ohms. Then change the meter to AC volts, start engine and meter should read 16 to 20 volts AC for every 1,000 RPM. If stator checks out then check voltage regulator with test lite grounded, touch regulator pins if test lite glows replace regulator. Good luck
Apr 09, 2014 | Harley Davidson FLHT Electra Glide...
How change starter on bajaj 200
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
How To Fix Replace GY6 Flywheel Cdi Stator and Magneto
Installing GY6 Stator
Bajaj Avenger 2006 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.marutibajaj.com/pdf/Avg-200.pdf
Bajaj Auto Avenger 200 User Manual
Feb 02, 2014 | Bajaj Motorcycles
Can you put stator engine cover of pulsar 150 2006
Hi, Raushan for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.How to Replace R6 Stator Stator Cover
How to replace Stater on 50cc scooter
https://www.tradebit.com/filesharing.php/search/0/bajaj+pulsar+150
bajaj Auto Spare Parts List All 2013
https://www.facebook.com/media/set/?set=a.497832643584730.119398.177568422277822&type=3
Sep 25, 2013 | Bajaj Motorcycles
Oil has gotten to my stater and has ran out of the stater plug, How can I fix it
If it is just leaking a little, remove the primary cover. Push the stator plug into the primary housing. Clean the plug and hole it goes into with brake cleaner. Apply black silicone to the outside of the stator plug and push back into the hole. Replace the primary cover, and after the silicone is dry, refill the primary. If oil is leaking alot, and the bike is a Twin Cam, check to make sure vent hose on the trans top cover isn't plugged. Twin Cam primaries vent through the trans and if the vent hose is plugged, oil will be under pressure in the primary and force itself out around the stator plug.
Jul 31, 2012 | Harley Davidson FLHR-FLHRI Road king...
Replacing stater
Hey Mike Perkins,
Click Here and Click Here for some images of Stators of the DR 350.
Good Luck
Jul 29, 2012 | 1991 Suzuki DR 350 S
Install stater and rotor
Hi Scott, for more information on your question please visit the websites below and good luck:
Stator Repair 1 of 9 Removing Inspection Cover on Outer Primary Cover
Jan 20, 2012 | 2006 Harley Davidson FXDI Dyna Super Glide
How to check stater on 1992 honda shadow
Locate the wire harness coming out of the stator on the left crank case cover of the motor and follow it to the plug with three yellow wires. This is the stator plug. You should have continuity between any combination of the three yellow wires, but no continuity between any of the yellow wires and ground. If the stator yellow wires are grounding you will have to replace the stator. To replace the stator remove the left crank case cover and unbolt the stator from the inside of the cover. Do not forget to purchase a new left cover gasket with the new stator or you will just delay your riding.
May 06, 2011 | 1992 Honda VT 600 C Shadow
Would a malfunctioning stater, not starter, stop my 1988 xt600 from starting? I have power running to all lights horn ext...., everything is working except ignition system. It only has power coming from...
typically a stator will not cause the bike not to start, unless it is grounded out and draining the battery, in which case nothing would work, or at least wouldnt work as well as normal. You have powerer from the regulator to the battery, so you would have to check the stator output to be sure, and check for a grounded stator. Unfortunately im not to familure with this make and model, so a service manual would be a great purchase for ya.
May 03, 2011 | Yamaha XT 600 E Motorcycles
Cub Cadet Riding Lawn Garden Zero Turn Tractor Logo
67 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
