Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
IHC 464 ruptured power steering hose. steering does not work.
The steering wheel turn freely but wheels do not move. Lots of fluid coming out from hose. I think hose needs replacing. Is this normal for a ruptured hose?
2 Suggested Answers
geo5734036
  • 528 Answers
SOURCE: steering wheel turns freely but
Follow the steering column down to the gearbox. You will see a "knuckle" that the arm goes into. It may possibly have a "donut" that looks like it's made of a tire - if not it will go into a metal flange that transfers movement to the gearbox.this is where you need to look closely and have a helper move the steering wheel as you are looking. The donut or the flange has broken and you will need to replace the part there.
Posted on Nov 22, 2010
Replaced powersteering hose and now the truck wont turn over
If you filled the power steering reservoir with the proper fluid (usually ATF), you should let the engine run for a while and try to turn the steering wheel a bit in either direction.
The wheels will hop a bit, you will feel like the power steering isn't working for a while, then it'll start working again and so on. Keep turning the wheel lock to lock until it works smoothly.
Keep an eye on the fluid level as you may need to refill the reservoir a couple of times as the fluid will be distributed in the power steering system.
Observe any strange sounds coming from the power steering pump and make sure not to keep the steering wheel turned to the limit as it may hurt the pump.
Nov 27, 2015 | Cars & Trucks
Something wrong with Power Steering
1. Check that the serpentine belt is still intact and still in position over all the pulleys on the engine including the power steering pump.
2. Check the power steering fluid level. If very low or empty you obviously have a significant power steering fluid leak which could be from a ruptured flexible hose, a leaky hose connection, a leak from the power steering pump itself or leaks from the fluid seals in the steering rack. If the PS pump has been run with very low fluid it will have been pumping air and will be damaged.
3. If the PS pump itself has failed you will obviously lose PS assistance and a bad pump would need to be replaced.
4. Since you have not checked anything on the car no one here can tell you the likely source of your particular PS failure.
5. The steering wheel should still turn but if the car is not moving it will be extremely heavy and difficult to move.without PS assistance so don't attempt to drive it in its present condition.
Nov 24, 2015 | 1996 Chrysler Town & Country
Power steering hard to turn
Engine running ask someone to turn steering wheel for you . Look for power steering hose move like there is pressure. and noise from power steering pump . if not change power steering pump
You don't really need power assistance when moving on the road ... where you need it more specially in parking or not really moving
hope it helps
Mar 31, 2014 | 2002 Chevrolet Tahoe
Chevy Impala leaking steering fluid and steering wheel stiff.
ck. p.s hoses 4 leakage fill pump have someone turn wheel back & forth look 4 leak
Nov 06, 2012 | 2000 Chevrolet Impala
Turning the wheel to far it makes sqealing sounds and doesn't want to turn
Have you checked your power steering fluid and made sure your pump is not slipping on the belt?
Jul 04, 2011 | 1998 Jeep Grand Cherokee
Power steering leaking is leaking by the boot at the wheel
Just need to replace the rack/pinion unit with a rebuilt from your local parts place. A common problem.
Mar 08, 2011 | 2001 Dodge Grand Caravan
Loud roaring from front right side goes away during a left curve then comes back when you straghten up
This is caused by a bad wheel bearing. to locate the right wheel jack the front wheels up and check for the wheel being loose, or with car jacked up in the air with front wheel off the ground put it in drive and see if you can listen for the noise, you may be right with the right front but just double check, good luck, hope this is helpful.
Feb 05, 2011 | 1993 Honda Accord
The power steering isn't working. The reservoir was empty and I added power steering fluid and it still very hard to steer
YOU HAVE A RUPTURE PRESSURE LINE IF YOU HAVE NO POWER STEERING FLUID IN THE POWER STEERING RESERVOIR.LOCATE LEAK THEN BLEED POWER STEERING SYSTEM BY ADDING POWER STEERING TO RESERVOIR.DONT OVER FILL BY FULL COLD MARK ON POWER STEERING DIP STICK.ADD FLUID TO RESERVOIR WAIT A 2 MINUTES.CHECK FLUID LEVEL AGAIN.WHEN POWER STEERING FLUID LEVEL STOP DROPPING.START ENGINE LET IT RUN FOR 10 SECONDS.THEN TURN OFF ENGINE CHECK POWER STEERING FLUID ADD FLUID IF FLUID LEVEL DROPS. WHEN FLUID LEVEL STOP DROPPING.SAFELY RAISE SUPPORT VECHICLE FRONT WHEELS.START ENGINE.NOW TURN STEERING WHEEL GENTLY FROM STOP TO STOP MEANING LEFT TO RIGHT DONT HOLD IN POSITION.LET THE STOP TO STOP BE QUICK.CHECK POWER STEERING FLUID AFTER YOU HAVE TURN STEERING WHEEL ABOUT 7 STOP TO STOP.WHEN FLUID LEVEL STOP DROPPING YOU AT HOT MARK ON DIP STICK BLEEDING PROCESS COMPLETE.TURN OFF ENGINE LOWER VECHICLE BACK TO GROUND WAIT ABOUT 5 MINUTES CHECK YOUR FLUID LEVEL.IF FLUID LOOKS LIKE A TAN COLOR.YOUR POWER STEERING SYSTEM FULL OF AIR.TURN OFF VECHICLE LET VECHICLE SET A LONG WHILE TO AIR BUBBLES SETTLE DOWN LOOK FOR LEAKS AROUND POWER STEERING PUMP FRONT SEAL AND CHECK FOR LEAKS AROUND POWER STEERING LINES.
Dec 01, 2010 | 1999 Oldsmobile Alero
After I replaced the power steering pump and reservoir on my 2002 Jeep, I still get air in the system. Where could it be coming from?
Your problem could be a pressure side hose that has a rupture that only leaks in extreme conditions. Inspect to replace with new to repair problem. First make sure you have removed the pump caps off of the hose fittings. If ok, it appears you may have a stuck valve in the rack assembly. Replacing the rack should solve your problem. ------- The new pump should be self-bleeding by turning the wheels left and right. Let sit over night to release air bubbles, recheck fluid level.------ Check the tension of the drive belts on the pump, as they may be loose. The power steering pump and reservoir is located on the front of the engine driven by one of the fan belts. There is a removable cap on the top with a dipstick attached. With the engine off, fill this up to the full mark with power steering fluid. Replace the cap, start the engine and check for leaks. On the back of the pump are two hoses either one could be leaking. REPAIR PROCEDURE:
1. Wipe the power steering cap and area free of dirt. Remove the power steering cap.
2. Use a siphon pump to remove as much fluid as possible from the power steering fluid reservoir.
3. With a helper in the vehicle, raise the vehicle on an appropriate hoist.
WARNING :POWER STEERING FLUID, ENGINE PARTS, AND THE EXHAUST SYSTEM MAY BE EXTREMELY HOT IF THE ENGINE HAS BEEN RUNNING. DO NOT START ENGINE WITH ANY LOOSE OR DISCONNECTED HOSES. DO NOT ALLOW HOSES OR POWER STEERING FLUID TO TOUCH HOT EXHAUST MANI FOLD OR CATALYST.
4. Locate the power steering cooler attached to the crossmember support plate. Slide back the clamp and disconnect one of the two power steering return hoses at the power steering oil cooler and drain fluid in an appropriate container.
5. Have the helper turn the steering wheel back and forth quickly several times to force as much fluid as possible from the steering gear.
6. Reconnect the hose at the oil cooler using the original clamp.
7. Lower vehicle so the vehicle tires are not contacting the ground.
9. For proper fluid fill and bleeding air from the power steering system:
a. Fill the power steering reservoir to the top of the fill range using Mopar power steering fluid (ATF+4) p/n 05013458AA.
b. With the engine OFF and the vehicles tires off the ground, slowly turn the steering wheel back and forth (lock to lock) slowly 20 times to force fluid into the steering gear.
c. Fill the power steering reservoir to the top of the fill range.
d. Start engine and let run for a few seconds, then turn oft engine.
e. Check fluid level and add if necessary.
f. Start engine, and slowly turn the steering wheel lightly contacting the left and right stops.
g. Stop the engine and check fluid level. Add fluid if necessary.
h. Lower vehicle, start engine and slowly turn steering wheel lock-to-lock.
I. Stop engine and check fluid level. Add fluid if necessary.
j. If fluid is extremely foamy, allow vehicle to stabilize a few minutes, then repeat steps "i" and "j" until the fluid level remains constant after running the engine and turning the steering wheel from lock to lock.
10. Inform the vehicle owner/operator that a steering vibration may be noted for a few hundred miles until the air is completely removed from the steering system.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 26, 2010 | Jeep Grand Cherokee Cars & Trucks
Leakage of Power Steering
Check your wheel bearing. Make sure all is tight and ok
Feb 07, 2009 | 1995 Ford Aerostar
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
18 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
