Question about Refrigerators
Frigidaire will not water
Ice maker works but won't dispense water
  • 50 Answers
You have a dual water valve one for water one for ice it needs to be replaced or it is the switch at the dispenser.
Posted on May 04, 2014
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire water dispenser won't work with new filter
The dispenser has a dual water control valves that control ice maker water and dispenser water. To find your parts you will need your refrigerators model number most time found around the fresh food sections door. Below I have a tutorial that may help you determine what may be the problem with dispensing water. Hope this helps, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire Refrigerators
Frigidaire side by side won't make ice but water comes from the dispenser
you either have a bad water valve,bad ice maker,also when was the last time you changed the filter?if it has a whirlpool ice maker you can pop off the cover on the ice maker,jump out the ice maker by sticking a jumper wire into the t and h,let it run for 15 to 20 seconds and pull the wire out,the ice maker should keep spinning,if it does go all the way around the water should come in when the white arms are at 11 oclock,if the water doesn't fill into the ice maker you can jump out the water valve from the ice maker,it says to jump it out from v to n but i jump it from v to L,if it fills with water the ice maker is bad,no water the valve is bad.you have a double valve,one for the dispenser and one for the ice maker but if one fails you have to change out the valve and it comes with both.next time send the full model number off of the machine and i can look it up and see what valve and ice maker is on your machine,when you find out what the problem is,call your parts store,give them the model number and they'll sell you the correct part.http://fixitnow.com/wp/2010/09/05/whirlpool-built-modular-icemaker-wiring-diagram-and-test-points/ copy and paste and it will show you how to jump out the ice maker.
Nov 14, 2011 | Refrigerators
Water dispenser and ice maker not working
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
