What is the flyback number for jvc 32720 - Televison & Video
I have sound but only a black screen on JVC LT-20DA6SK
Is there a light from the CRT filament? if so.. adjust the "screen" screw at the back of the Flyback slowly. Measure the G2 pin for almost 4k to 6k DC volts, dont let the screen shows horizontal lines or flyback lines.
Sep 30, 2014 | JVC Televison & Video
How can i know the model number of flyback... of my JVC crt tv 21 inches model AV-21BA17B?
Refer its repair manual; or contact the authorized service center for JVC.
Electro help
Aug 28, 2014 | Televison & Video
JVC 29 inch Color tv Model no 29ss16 flyback no JFO 501-21168 is not available in Pakistan Please tell me Flyback Replacemint No?
Just try this link. It has circuit diagrams to some popular brand CRT TVs. Hopes that it might help you find out the exact number of the flyback transformer. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 16, 2014 | Thomson 14MG135 14" TV
How do i know the flyback number of this model JVC AV-21VA15
Download the repair manual to this set by internet. It has all details.
Jan 25, 2013 | Televison & Video
Need a flyback transformer
This part rarely fails in this set so let me know if sweep transistor is shorted or what?
To answer: Contact JVC with the correct model number and try to get the part number---nothing JVC will be cheap but with the actual part number you can Google to see if available.
I would also suggest checking someone like Suburban Electronics who sells a lot of these parts---online catalog and or phone.
SD TECH
Oct 21, 2012 | JVC AV-48WP30 48" Rear Projection...
Black screen horizontal white line
vertical scanning circuit is Defective.this is not hard to repair.contact service technician
Jun 15, 2011 | JVC AV-32720 32" TV
Tv has power, can hear sound, but picture is black. when i shut it off a horizontal white line appears for a short second. can this be easily fixed?
Well, If you are technically sound, you can fixed it, but I will like you to check the line Or Fly-back Transformer and the horizontal and vertical side of the circuit very well.
Video just reduced to a tiny horizontal line across the screen. sound is fine, what could be the problem? jvc tv model av-32720
You have a bad vertical IC at its worse or one that may need resoldered. Be sure to check the grounds on this IC and check for rings around the pins. And you can bet in the immediate area you have bad capacitors that created a hot vertical IC. This will cause the Vertical IC to break down!
May 02, 2010 | JVC AV-32720 32" TV
My jvc av-32890 makes a click and shuts off 95% of the time.It will not stay on and when it does it is only for a few seconds.
maybe your flyback. check b+ on the flyback. If you dont have voltage you can unsolder b+ pin on flyback and feed a 75 watt lamp to verify if power supply or flyback trouble.I think it`s pin 9 on flyback. look for print b+ on pcb.
Apr 23, 2010 | JVC AV-32890 32" TV
Hernandez030763@yahoo.es
The flyback for JVC C-13910 is listed below. Do you have the location number for the IC Regulator?
JVC C-13910 Flyback T1522
Apr 22, 2008 | JVC C-13910 13" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
