Question about Xante Ilumina Digital Color Press Printer
Mp tray raise crooked. Paper not square into feed
Had a tech here last time and he opened a door below MP tray and did something and then the tray raise straight?
MP Tray not feeding
Clean the rollers with q-tip and acohol
Feb 20, 2016 | Brother HL-4070CDW Printer
How do I clear a scanner jam for a MFC 8480
Hi Judy,
Please follow the steps posted below:
1. Remove the paper from the MP tray
2. Remove any jammed paper from in and
around the MP tray
3. Close the MP tray. Then open the front
cover and close it to reset the machine.
4. Open the MP tray again
5. Fan the paper stack, and then put it back
in the MP tray
6. When loading paper in the MP tray,
make sure that the paper stays under
the maximum paper height guides on
both sides of the tray
Let me know if this resolves the issue,
Thanks,
Hunter Quinn
IBM Help Desk
Dec 04, 2014 | Brother MFC Office Equipment & Supplies
Where is the MP tray?
It's the small door at the very front of the machine...located directly above the main paper feed tray. Just pull it open and lower it down. MP stands for Multi-Purpose and is for different paper types and sizes that are not available from the main tray.
Oct 12, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Trey 1 is giving a message out of paper when they is paper inside
The message "No Paper" will appear on the LCD display if the Brother machine does not detect paper in the paper tray(Tray#1 or Tray#2) or MP(Multi-purpose) Tray.
Resetting the Brother machine may resolve this issue. To reset the machine, unplug the power cord from the AC power outlet for approximately 10 seconds and then plug it back in.
Note
For MFC users :
The Brother machine can be powered OFF for up to 4 days without losing faxes in memory.
If the message "No Paper" continues to appear on the display follow the instructions listed below:
When printing from Tray#1 or Tray#2 :
Pull the paper tray completely out of the machine. Go to STEP2.
When printing from MP Tray :
Go to STEP4.
Note Tray #2 is the optional LT-5300 paper tray.The MP Tray is just above the main paper tray and can be accessed by opening the MP Tray door. To open, pull on either the left or right side of the front door by the circular cut out.
2. While pressing the blue paper-guide release lever, slide the paper guides to fit the paper size. If the back of the paper tray doesn't move, the tray lock button may be in the lock position; slide the lock button to the unlock position and pull out the back of the paper tray again. With the paper removed, you will see the LTR (letter) marking on the plastic plate on the bottom of the paper tray to indicate where the moveable rear guide (with protruding arrow) should be moved to for letter size paper. There is also a marking for legal size paper. Make sure the guides are set at the correct mark. Reload the paper in the paper tray. Make sure the moveable rear guide does NOT push tightly against the paper. It should be adjusted to the LTR (letter) or LGL (legal) position, depending on your paper size. If the moveable rear guide is pushed too tightly against the rear edge of the paper, the paper will get stuck in the tray and a loud plastic snapping noise may be heard when feeding paper.
3. Move the tray lock button to the lock position (slide the button towards the paper).
4. If there is no paper in the tray, reload the paper.
The tray can hold up to 250 sheets of 20lb paper. Do not overfill the tray. There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic.
Note
If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed tray. Make sure you insert the paper far enough --about 1 inch- under the gray plastic bar in the MP Tray until it stops or it will not be fed and the machine will display the message "No Paper".
5. Verify the correct size and type paper is being used:
If you are printing from a PC and using the paper tray, make sure that MP Tray is NOT selected in the application's print properties for Paper Source.
If you are printing from a PC make sure that the MP Tray is selected in the application's print properties for Paper Source.
Note: Please be aware that the setting in the printer driver will take priority over the setting made on the control panel.
14. If you have set the Tray Use settings for a particular tray, the machine will feed paper only from that tray. If the selected tray is out of paper, a "No Paper" message will appear on the LCD. You need to reload paper in that tray.
To set the Tray Use setting, follow the steps below:
a. Press Menu.
b. Press the up or down arrow key to select General Setup.
c. Press OK.
d. Press the up or down arrow key to select Tray Use.
e. Press OK.
f. Press the up or down arrow key to select the mode you want to use.
You can select Copy, Print or Fax(MFC users only).
g. Press OK.
h. Press the up or down arrow key to select the tray.
You can select Tray#1 Only, Tray#2 Only or MP Tray Only.
i. Press OK.
15. For MFC users :
To test, print the Help List.
. Press Menu.
a. Press the up or down arrow key to select Print Reports, and press OK.
b. Press the up or down arrow key to select Help List, and press OK.
c.Press Start.
For DCP users :
To test, print the User Settings.
d. Press Menu.
e. Press the up or down arrow key to select General Setup, and press OK.
f. Press the up or down arrow key to select User Settings, and press OK.
g. Press Start.
Note
If the problem still continues after following the above instructions,
I recommend you clean the Separation Roller, Pickup Roller and Separation pad following the instructions of the FAQ: My Brother machine mis-feeds paper.
Apr 21, 2012 | Brother MFC-8460N All-In-One Printer
Manual feed isnt working. once tray 1 is open i thought it would automatically know i want to use manual feed.
Not necesarily so, it depends on how you have the printer configured. To test the MP tray, use the arrow keys to get to troubleshooting menu, press check, use arrow keys to get to paper path test, press check, set tray option to tray 1, then print test page. Printer should feed from MP tray. If it does, then the problem is that you do not have the printer set to print from MP tray first or you have the tray options set to exclusive which means that if your print job asks for tray 2 then printer will not print from MP tray unless you specify MP tray in the print options.
Mar 18, 2011 | HP LaserJet P4015 Printer
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Mar 18, 2011 | Brother HL 5250DN Laser Printer
Where is MP tray?
The MP Tray is just above the main paper tray and can be accessed by opening the MP Tray door. To open, pull on either the left or right side of the front door by the circular cutout.
Dec 01, 2010 | Brother MFC-8660DN 5-in-1 Laser...
Printing envelopes on the Oki C5250
There are 2 entrances into the multi purpose tray. The one I needed access to opened from the sides and not the front (which opened the entire front cover). There was then a flap inside which allowed me to adjust the size of the documents to feed in, including envelopes, which the main tray doesn't.
Mar 18, 2009 | OKI C5250n Printer
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Oct 22, 2008 | IBM Infoprint 1422 Laser Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
