Question about Dryers
Frigidaire affinity dryer
I have a affinity dryer, when you first turn it on it makes a squealing noise like somthing is loose fora second then it sounds fine untill next time you turn it on
  • 957 Answers
Most likely it is the wheel that the belt runs on to turn the drum. It may need to be replaced or you could try to put some white grease on it. be sure not to get any on the belt or it will make it slip and smoke
Posted on Apr 02, 2014
  • 883 Answers
SOURCE: squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Posted on Dec 26, 2007
  • 1028 Answers
SOURCE: Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Posted on Jul 08, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
Frigidaire affinity front load dryer
You need an upper felt and a rear drum bearing. If you buy the felt make sure you get the special adhesive to install it. The squeal maybe part of this or it could be the rear drum bearing. You can learn how to replace the rear drum bearing here in the article I wrote. http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
Jan 29, 2014 | Dryers
Noise
wave touch or iq touch service manual.
Might be a roller or idler or maybe something in the blower housing. I have included the service manual for a late model affinity dryer. good luck on your repairs. If the link don't work do not blame me, blame FixYa. LOL
May 14, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Fridgidaire affinity dryer making very loud vibrating noise when running
Hello - From what you have described it sounds like you either have a problem with the belt, front and/or rear bearing, or a loose connection with the motor or drum. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replace depending if they are worn, damaged or loose.
Dec 10, 2012 | Frigidaire Affinity AEQ6000WH Dryer
When the dryer starts it makes a horrible squealing noise and then stops running within 5 mins..all lights flash on with error code Ad...no clue what I should be looking for to fix this
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 19, 2011 | Electrolux Frigidaire Affinity 5.8 cu. ft....
Frigidaire heavy duty electric dryer started with sqeaking noises now is knocking belt appears in place drum turns mannually feel somthing loose between drum and rear cover
heatman101
Jun 14, 2011 | Frigidaire GLGR642A Gas Dryer
Dryers Logo
Top Dryers Experts
