Question about Genicom Epson Workforce Pro Wp-4540 Wp4540 All-in-one Wireless Color Printer
Wp4540 leaking ink
Yellow ink everywhere
Why is the plotter ink leaking
Depends on where the ink is leaking. Could be a failed seal on the ink pressure system, or a leak where the cartridge mounts into the printer. If the ink is everywhere, then likely part of the pressure system has failed. If it is just dripping then suspect a faulty cartridge or printhead.
Jan 18, 2015 | Canon imagePROGRAF iPF610 - large-format -...
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
I850 canon printer blinks yellow 7 times wont print ,did the waste reset still no good is this a print head failure
You don't want to do a waste reset, ink will overflow everywhere.. but waste ink full is what the 7 blinks means. Resetting the waste ink is like adjusting your gas gauge and not putting gas in, not a good idea...
Jun 05, 2009 | Canon i850 InkJet Photo Printer
Need repair on a HP1055CM plotter in Toledo Ohio
it is all one assembly. You will need to call a technician.
Jan 06, 2009 | HP DesignJet 1050c InkJet Printer
Colors are not printing properly
Looks like your printer head is in need of replacement
Nov 11, 2008 | Canon i950 InkJet Photo Printer
Help! Yellow note pad everywhre.
There is a program called Ink - you'll find it in your system preferences under the apple menu. You need to turn it off. This will allow you to use your wacom without that annoying yellow notepad everywhere!!
Oct 05, 2008 | Wacom Intuos3 Graphic Tablet
Yellow ink leak
This would be best addressed by an HP repair center - trying to repair this on your own may result in more damage to the printing system.
Depending on your date of purchase, you may be fully or partially covered under your 1 year, parts and labor limited warranty.
Best of luck
Apr 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother MFC-215C leaking ink
Buy a new printer ....unless it is a dodgy refilled magenta ink that is leaking,  if you are indeed using genuine Brother Inks then it will need a purge unit which is too costly to repair
Oct 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Genicom Epson Workforce Pro Wp-4540 Wp4540 All-in-one Wireless Color Printer Logo
20 people viewed this question
Top Genicom Office Equipment & Supplies Experts
k24674
Are you a Genicom Office Equipment and Supply Expert? Answer questions, earn points and help others
