Question about Taylor 794-27 Soft Serve Twin Twist Water Cooled Frozen Ice Cream Machine
Need part # for toggle switch and micro switch on model# 702-27 serial k3036117
Keeps running not stopping
I’m repairing a older Taylor Y152-12 machine it’s a older model but has served us well. It’s a H model, R502. The compressor does not want to stop. It keeps freezing.
replace the faulty thermostat
there should be a thermostat model etched on it some where and any unit with the same set up will replace it
Dec 22, 2017 | Taylor Ice Cream Makers
I bought a Taylor soft serve ice cream model #754-33 and serial #k1126268 I need to know how to set it and make ice cream?
too hard to explain online, you need to contact your local taylor dist. or a local service company who might install or know about them.
Feb 19, 2015 | Taylor Ice Cream Makers
On the soft Serve side of my Taylor ice cream machine it is freezing up and not letting any product come out pump still works don't know what the problem is I take everything apart clean it put it back...
if the product is frozen in the barrle for sure then you have a bad micro switch that is telling the compressor to keep running, but that product would be super frozen and come out in the shape of the barrel. if it is the consistancy of ice cream then your pump gasket might be bad and not properly pressurizing your barrel and giving you the impression of a frozen barrel.
Put a new motor in the left side, but when you try to run it, it keeps tripping the reset button and turning off. The left side controls the hopper cooler, so I come in and the hopper is warm on both...
Did you check the wiring ? This motor is reversible and you may not have the wires under the connection plate. A model number would be very helpful as I am looking at model # 339 manual.http://www.taylorfreezersales.com/op_man/0336_338_339op0.pdf
Jun 29, 2011 | Taylor Ice Cream Makers
I HAVE A TOGGLE SWITCH ON THE BOTTOM OF MY MACHINE. WHATS IT FOR???
I have been unable to locate the toggle switch in a SaniServ Operational Manual located HERE , I suggest you call and ask Saniserv what this toggle switch is for 800-733-8073
Thumbs up if this helped!!!
Jun 21, 2011 | SaniServ 401 20 Quart Ice Cream Maker
Wiring diag. for mod. 407-E Ice Cream Maker
Need the serial number, voltage (ie; 115v or 208v), 60 or 50 hz.
The only exact diagram for an 407-e is 50hz.
An M will be close in most cases as long as we have the serial number or Mfg. date code.
If it is a 407-e 115/60Hz with a blue id plate it is at least 15 yrs old.
Nov 09, 2010 | SaniServ 407 10 Quart Ice Cream Maker
I need parts list
spec for belting - size and mesurement
Jul 11, 2010 | SaniServ 401 20 Quart Ice Cream Maker
I need beater with its blade and a pipe for taylor machine
you can call Rick at Restaurant Parts and More, 1-888-814-1110. Have you model and serial numbers. He can most likely help you.
Apr 14, 2010 | Taylor 632-33 Ice Cream Maker
Taylor 751 sp dead
Sound like you might have a loose wire or ribbon cable,might even be a loose wire on switch.Be sure to turn breaker off to machine and unplug it before you check them. Also check the motor reset.
Jan 24, 2009 | Taylor 632-27 Ice Cream Maker
Musso Switch
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Mar 18, 2008 | Musso Stainless Steel Pola Ice Cream Maker
Taylor 794-27 Soft Serve Twin Twist Water Cooled Frozen Ice Cream Machine Logo
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
