Question about Night Owl Optics Binocular - NOBG 1
Nobg 1 Lense assembly diagram to put it back together
Drill fell and broke now trying to put it back together gears and all,require help
Unfortunately on that model they do not service any of the transmission parts separately so there is no exploded view. Here is the parts diagram. You may end up having to buy a new trans assembly.
DeWalt DC987K diagram
Aug 10, 2012 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Putting back together the rear drum brakes on a 1998 chevy lumina need to know how to put them back together
Auto Zone usually has a diagram on there computer ...showing all the springs etc. to re-assemble a drum break .
Jan 09, 2010 | 1998 Chevrolet Lumina
Rear Brake Assembly
Go to autozone.com Type in what car you have. then go to the repair section it will have a diagram of how to put it back together.
May 25, 2009 | 2003 Saturn L-Series
I have broken my HP Photosmart R817
I just fixed mine and what came out of the end of the lense housing was the shutter assembly. Your camera will still work but the shutter will not operate for protecting your lense.
What was on the ground from the shutter assembly looked like six parts but actually there's eight:
1 - Front round plate (what you see if shutter assembly was still in the lense housing).
2 - Hair size springs that hopefully stayed in the sides of the front round plate. IF NOT OR EITHER ARE LOST, THE SHUTTERS CAN'T BE SET TO CLOSE SO SKIP THE STEPS BELOW ABOUT INSTALLING THE BLADES.
1 - back round plate (black with four tabs).
2 - Larger L-shaped blades.
2 - Smaller L-shaped blades.
Place the front round plate with cosmetic (engraved 'PENTAX...) side down and look at the inside for two round mounting posts on the left and right. You will be using the larger of the two posts on each side for placing the L-shaped blades.
Place the larger L-shape blades with the hole end onto the posts. Blades should swing freely and their backs match with the shape of the inside of the front plate when open.
Place the smaller L-shape blades on top of their respective larger L-shape blades with the hole end onto the same posts used in the last step. Blades should swing freely and their backs match with the shape of the inside of the front plate when open along with the larger L-shape blades.
Springs (long ends) will need to notch into the smaller L-shape piece end (nearest the hole/post end). This is a real trickly part of the assembly and I used two tools like large pins or needles to pry the spring into the notch. If you can't do this, no sense in even leaving the four L-shaped blades inside of the front round plate since the shutter will not close properly without the springs.
Align and snap the back round plate tabs onto the front round plate. The shutter assembly is now ready to put back into the lense assembly.
MAKE SURE THE CAMERA IS IN THE OFF POSITION AND THE LENSE ASSEMBLY IS RETRACTED!
Align the front of the shutter assembly with the engraved wording properly oriented (not sideways, not upside down, etc.) and press gently into the lense assembly until completely in the end of the housing.
If blades were installed properly, they will open when the camera is turned on, and close when the camera is turned off.
If blades were not installed, the empty shutter assembly (back round plate snapped onto front round plate) can still be pressed into the lense housing...the shutter will just not work and the lense will always be exposed. Actually, this is one helluva lot easier than fixing the shutter assembly and not the end of the world for your camera's operation!
Mar 23, 2008 | HP Photosmart R817 Digital Camera
Night Owl Optics Binocular - NOBG 1 Logo
Top Night Owl Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Night Owl Optic Expert? Answer questions, earn points and help others
