Question about Evenflo Journey 300 Embrace35 Travel System - Koi
Loose carrying handle it jiggles now
It didn't move at all before this has me very scared i don't want my baby to fall is there any way to fix that?
Hi my handle bar is not locking into place and easily swaps between off road mode and normal, is this kind of thing fixable??
This is not safe and you can call bugaboo, give them the number on your chasis and they will be able to help you. They will most likely replace since it is a big problem as it is the carry handle.
Feb 04, 2013 | Bugaboo Cameleon Baby Gear
Quinny pushchair
Hi
Under standard warranty terms and conditions the product should be returned to your retailer with proof of purchase for a warranty claim to be made.
Aug 07, 2012 | Quinny Zapp Xtra Travel System Stroller
Loose handles on bugaboo cameleon
The handles on a Bugaboo move up and down about 1 inch / 24 mm thats normal. If they don't lock at all or only one side does thats a problem and the answers here, www1.fixya.com/support/r7805199-fix_bugaboo_handle_lock
Sep 26, 2011 | Bugaboo Cameleon Jogger
Handle is stuck in the carry position--Can it be fixed?
These car seats seem to have a problem in the release mechanism that
lets the handle move. We have found that lifting the handle a bit as you press
the releases can help. Try pulling toward the front of the car seat, then pressing
the release buttons. If all else fails, call Baby Trend and complain. It just might
get you a replacement if you can prove it is a danger to the child in the seat.
Baby Trend, Inc.,
1607 S. Campus Avenue, Ontario, CA 91761
By Phone: 1-800-328-7363
Mar 26, 2011 | Baby Trend Flex-Loc Infant Car Seat -...
Can't move the carrying handle on tyhe evenflo cozy carseat
Hello Vicki,
Please click on this link it will allow you to find instruction manual for your model. www.evenflo.com has production information on it. You can also call the technical support line at Please Call Us
US: 1-800-233-5921
Canada: 1-937-773-3971
Hours of Operation
Monday - Friday
8:00 a.m. – 5:00 p.m.
Eastern Standard Time
The carrier should have two buttons that you should be able to push in on the left and right side and all at the same time pulling the handle to the very back of carried.
Apr 27, 2010 | Evenflo Cozy Carry 5
I have a first years bassinet Model # Y11047, I need to know how to get the "carry-me-near ergonomic handle back down once it is in th carrying position. I don't see any buttons to release the handle
Ther are two levers on the bottom of the handle that you have to pull up to release the handle to be moved. It would be the same ones when unfolding from the travel postion.
Apr 18, 2010 | The First Years Carry-Me-Near 3-in-1...
My maxi cosi tobi seat wont recline
Yes it seems to be a design fault. Has happened twice on our Tobi seat.
To fix, lay the seat on its back.
Locate the 3 Torx head screws middle front and rear left and right. You'll need a Torx screwdriver or head of the correct size. http://en.wikipedia.org/wiki/Torx
Undo the screws, then pop the four catches at each corner with a flat-head screwdriver and remove the base.
Look at the recline mechanism, you'll see large bar at the rear (both sides) which is meant to be there. At the front, on one side or the other, you'll see a smaller bar which is part of the hinge for the recline handle. It's slipped sideways and into one of the recline mechanism slots.
Jiggle the recline handle and push the hinge bar back into the centre. It might help to use gravity - lay the seat on its side with the blocking bar uppermost. I can't see a way to prevent this slipping out again over time.
Snap the base back on and replace the Torx screws.
Jan 03, 2010 | Baby Gear
I just got a bugaboo cameleon, and the handles seems to be loose...
They all seem to be loose....or have you compared it to another that is not loose? The nature of the mechanism lends itself to feeling loose.
Aug 21, 2008 | Bugaboo Cameleon Jogger
WHEELS!!!
you have to replace the spring inside the wheel hub. the same thing was happening to me and my husband made a new spring out of spring steel. I guess they just loose their strength after a while. It was very frustrating!
Dec 12, 2006 | Bertini 906T TWIN - Navy Check Standard...
Evenflo Journey 300 Embrace35 Travel System - Koi Logo
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
