Question about LG Washing Machines
Need replacement inside flint
Inside flint cacher is old and needs to be replaced--where and how much?
  • LG Master
  • 17,093 Answers
Need to know the exact model number
Posted on Apr 01, 2014
HOW DO I REPLACE THE FLINT OF A ZD41 LIGHTER
You've posted this in the car and truck section. I'll try and help.
Is this a higher quality refillable lighter? If it isn't refillable i wouldn't waste time replacing the flint. Just buy a new lighter. Are you sure it has a flint as some lighters have electronic sparks.
Try gently pulling the roller straight up. Some makers fit the flint as a pull out so you can replace the flint from below the roller.
If you really need to change the flint you will have to lever out the roller. NOTE, the flint will be spring loaded so might pop out as you remove the roller.
Feb 05, 2018 | Cars & Trucks
I put a flint and fluid in my old Ronson lighter, and it STILL won't spark.
Hey Vicki, Did you remove all pieces of the old flint?? it needs to be clean.. The spark wheel must make good contact..(could the spark wheel be worn out??)..Some spark wheels have the carbide only on the edges as rings that do the sparking.. some very high end lighters have a solid carbide wheel..$$... make sure the sparking wheel is making good contact..(you may have to stretch the spring that pushes up on the flint..just a little... good luck..
Jul 17, 2017 | Cars & Trucks
How do you unblock the gas jet. The flint on the heater is working but the gas is not flowing, although you can smell it when it is on?
If you are not mechanically inclined, DON'T TRY TO DISASSEMBLE, CLEAN, AND REASSEMBLE !!!!!!!!! CALL A PROFESSIONAL !!!!!!!! If you can do the above tasks to the heater, the jet mostly needs replacing. You'll need a cleaning kit with long handle wire brushes, and a can of computer cleaning compressed air. Make sure gas is turned off inside the house and outside the house if possible. CAREFULLY disassemble the heater. If any fittings get damaged, you have to replace the part. All the parts have to be fit perfectly!!! Use the wire brushes to clean the inside of tubes and use air can to blow inside of tubes.
May 16, 2016 | Heating & Cooling
My oven won't light. is it the flint that needs replacing or do I need a new oven?
unless it is a really really old oven then it will have a pizo as a starter
if it is nor sparking when you press the button then get a gas technician to replace it or fix the jet fault.
May 20, 2015 | Ovens
Where can I purchase a flint for my Weller Portasol butane solderer?
I am looking at my Weller Portasol P-1k unit right now. They use standard flints. Go to almost ANY store you can think of and they sell lighter fluid and flints (usually sold in a pack of 5). About a buck or two.
Oct 30, 2012 | Weller Welding Tools
How do I replace the flint on an old Omega Super Lighter? The old flint appears to be 'corroded' in its tube and I don't want to break it...otherwise the lighter is in great shape.
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 25, 2012 | Cars & Trucks
Blazer pocket micro torch will not spark. Gas comes out, but no spark to ignite it.
try to open up the part where the spark would come from. there should be a screw on the bottom or top to open it. This is where the flint would be.
The flint is probably worn down or it broke (you can buy new flints at pretty much any convince store around they are i believe $1-2 for 5 of them.
replace the flint and you will have a spark.
May 03, 2011 | Omega Blazer Self - Igniting Butane Micro...
I have an old flint style/butane fuled lighter
Google vintage lighters---vendors often have a repair shop
Feb 23, 2010 | Hand Tools
How to fit a flint in a vintage dunhill pistolttable lighter?
On the underside opposite the flint there should a screw head.
Remove this screw (take care, there will be a spring inside!) .
Turn it over and the remains of the old flint should drop out.
Insert new flint and re-assemble.
Jan 16, 2010 | Watches
Fixing Rowenta lighter
Pull apart in 2 parts...
Apr 06, 2009 | Sport & Outdoor - Others
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
