Question about Grohe Model 28 206 OOO: Ladylux Plus Deluxe Champagne shower head - Chrome
Replace cartridge on grohe kitchen faucet ladylux
3 Suggested Answers
  • 52 Answers
SOURCE: Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Posted on Feb 15, 2010
shadows865
SOURCE: How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Posted on Aug 14, 2012
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Low hot water pressure on Grohe LadyLux.
1. If by replacing the flexible hose you mean the hose for the pull-out portion - you have more than likely kinked or bent the supply line to the hot (left) side of the faucet.
a) If this supply is braided, then simply shutting of the water supply, removing the braided line and either replacing or attempting to straighten it out will be your best bet.
b) If the supply is copper, you will have to cut the line cleanly and carefully. you will then most likely need a 1/4" or 3/8" compression/quickconnect BY 1/2" IP fitting to complete your repair.
2. Other possibilities include:
a) Failure inside the faucet body which will most likely be warrantied by Grohe if you push them hard enough.
b) A problem at your hot water tank, most likely the outlet side and *perhaps* you hadn't noticed the problem elsewhere.
c) The hot valve failing to reopen fully despite all appearances; applies if you turned off the water under the sink for your repair.
Aug 05, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe ladylux plus is leaking
I believe there is a cartrige that has some washers in the unit. There may be some debris caught in there since it was a little loose. I would turn the water off and disassymble the unit and replace any obvious washers and clean everthing up. Replace it all and try it again. If it still leaks, contact Grohe for more trouble shooting. Faucets have fantastic warranties and companies usually will send replacement parts free of charge at times. Hope this helps.
Apr 06, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe Model 28 206 OOO: Ladylux Plus Deluxe Champagne shower head - Chrome Logo
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
