Question about Taylor 702-27 Tabletop Soft Ice Cream Machine W/ Table 1ph 2008 Model Nice
Keep running they put new toggle switch on got from ace hardware ??? I know!! need part # for toggle switch and micro switchs as well
On the soft Serve side of my Taylor ice cream machine it is freezing up and not letting any product come out pump still works don't know what the problem is I take everything apart clean it put it back...
if the product is frozen in the barrle for sure then you have a bad micro switch that is telling the compressor to keep running, but that product would be super frozen and come out in the shape of the barrel. if it is the consistancy of ice cream then your pump gasket might be bad and not properly pressurizing your barrel and giving you the impression of a frozen barrel.
Feb 19, 2015 | Taylor Ice Cream Makers
I got new switches for Musso Stella ice cream machine. Cannot figure out how to get into the thing to replace the switch! How do you take off the top of the machine so you can get to the switch connec
Try using ice. It will shrink the part slighty enough to pull it out.Boiling water will make the the parts expand.If you use oil, use a penetratig oil only. Spray in the oil, have a beer, and the try to pull out the stem. Do not use heat. Hope this helps.
Dec 06, 2014 | Musso Ice Cream Makers
In phase ips248bt
make this test and fix it. God bless you
  1. Interlock switch If your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control board If your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Dec 12, 2013 | Ice Cream Makers
Put a new motor in the left side, but when you try to run it, it keeps tripping the reset button and turning off. The left side controls the hopper cooler, so I come in and the hopper is warm on both...
Did you check the wiring ? This motor is reversible and you may not have the wires under the connection plate. A model number would be very helpful as I am looking at model # 339 manual.http://www.taylorfreezersales.com/op_man/0336_338_339op0.pdf
Jun 29, 2011 | Taylor Ice Cream Makers
I HAVE A TOGGLE SWITCH ON THE BOTTOM OF MY MACHINE. WHATS IT FOR???
I have been unable to locate the toggle switch in a SaniServ Operational Manual located HERE , I suggest you call and ask Saniserv what this toggle switch is for 800-733-8073
Thumbs up if this helped!!!
Jun 21, 2011 | SaniServ 401 20 Quart Ice Cream Maker
I have a sterling ice cream freezer the can has rust spoy-ts in it can i get a new can
Is there a Ace Hardware store in your area? If anyone can get you a replacement (aside from the manufacturer) it will be Ace.
These rust spots ... outside or inside? If outside ... use the can as is.
Thanks for your interest in FixYa.com
Jul 05, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
I purchased a 6 qt ice cream maker in June 2009, fron Ace Hardware. I used it 5 or 6 times and now 2 small holes developed in the cannister contaminating the ice cream with salt. Can I get a new cannister...
It should be replaced, but sometimes Manufactuers warranties are deceptive. This may not be a manufacturers fault. It may be caused by corrosion which is not the fault of manufacture.Cagey very cagey! but there is no harm in trying your luck.
Please rate our help++++Thankis for using FIXYA
Oct 12, 2009 | Ice Cream Makers
Instructions for coffeemaker cuisinart DC1200 need to know how to set the automatic time for cooffemaker
Turn dial to PROG
Press and release HR button a few times - it will have a "PM" on the display if it is set for PM
Press and release MIN button until minutes are set
Once the time you want it to go off is selected, turn the function knob to AUTO-ON - flick the switch to ON - a green light will now illuminate and you are ready to go (don't forget to put water in the reservoir and coffee in the filter basket)
Sep 24, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Ice cream maker "agitator" broke
I searched in vain to find a standalone part for the Rival 8401-M, but here are some leads:
You can call Rival and see if they still have the part in stock, although it is doubtful since they don't even have support for the machine on their website anymore.
I found several never-opened and used Rival 8401-M's in working condition on eBay and other places on the web, ranging in price from $16.00 - $35.00. For electronic products that are more than 4 years old, I reccomend buying used, because a unit that is NIB (New-In-Box) may be dead as a doornail (The analogy I use is this: if you have a Ferrari, no matter how well-built, and you let it sit unused for 7 years - when you go to start up that Ferrari after 7 years, it's not going to work because the parts have degraded, etc over that time period). Here is alink to an auction for a working, used Rival 8401-M
If your blade is broken, I did not find replacement blades anywhere on the web. If it is, in fact, the agitator that is broken, I have two leads:
Here is a web site that will show you what an agitator looks like (it is the tiny part that they are pointing to in red):
http://www.twinsupply.com/proddetail.asp?prod=176-1055&partner=herb
Ace Hardware, at one point, stocked the Rival 8401-M - if you take it in to them, you can see if they have an agitator that would work (if it is, in fact, the agitator, and not the blade that is broken).
My final reccomendation is tongue-in-cheek: Buy a new Cuisinart ice-cream maker instead - a simple one like the ICE-20 can be had for $20-$40 brand new.
-Tha Mp3 Doctor
Mar 17, 2009 | Rival 8401-M 4 Quart Ice Cream Maker
Taylor 751 sp dead
Sound like you might have a loose wire or ribbon cable,might even be a loose wire on switch.Be sure to turn breaker off to machine and unplug it before you check them. Also check the motor reset.
Jan 24, 2009 | Taylor 632-27 Ice Cream Maker
Taylor 702-27 Tabletop Soft Ice Cream Machine W/ Table 1ph 2008 Model Nice Logo
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
