Question about Sony Bravia XBR KDL-40XBR6 40-Inch 1080p 120Hz LCD HDTV
SONY KDL-40XBR6 12 BLINKS (I HAVE NO IMAGE, BUT SOUND)
INVERTER REPLACED FOR USED ONE, BUT SAME RESULTS.
  • Sony Master
  • 3,904 Answers
I would be more inclined to check the power supply board first. Check the outputs to make sure the voltage is correct getting to the inverter. You should be able to pull up specs online if the expected voltages are not already printed on the board itself.
Posted on Apr 02, 2014
JOHNSONELECT
  • 113 Answers
SOURCE: KDL-40v3000 flashes for 2 seconds then goes black
have you check the voltage from the power supply thats goes to invertor maybe its low the power supply would be bad
Posted on Aug 27, 2009
  • 1684 Answers
SOURCE: 13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at: http://www.ccl-la.com/forum/index.php Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Mar 13, 2010
welcomejee
  • 10594 Answers
SOURCE: sony kdl-32v2500 with selfdiagnose 4 times
Back light inverter is mounted on left side of lcd panel if you see it rear and subject board would be covered with some shield. Remove screws of shield and circuit board, unplug connectors and take it out. Put new board, plug connectors, tight screws.
Posted on Jun 23, 2010
caroldon
  • 17130 Answers
SOURCE: Sony KDL-46XBR4 - no picture or sound (black screen), the standby led blinks once then recycles each time the sony lights then goes out after 30 -50 mins the set comes on.
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time. Based on the above method you must be able to locate the area of fault and solder the sections.
Posted on Oct 24, 2011
  • 430 Answers
SOURCE: Sony kdl-46w4150 standby blinks 8 times
Click the link below :----http://wikisolutions.blogspot.in/2012/02/get-free-answers.html
Posted on Feb 12, 2012
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
CAN YOU DIRECT ME TO EITHER THE INVERTER BOARD OR THE MAIN BOARD.
Hello Calvin,
I would suggest to change the input to a video with audio source to eliminate a main board failure.
If the back lights are not working, this could indicate that the inverter board is defective but there could also be a defective CCFL light failure.
You can find service parts in the link provided.
Let me know if you required further assistance. Search results for kdl 40bx450
Jun 08, 2017 | Sony Televison & Video
What's six red blinks at sony tv?
Hi, [Error code 6. LED flashes 6 times]. Malfunction of inverter or overcurrent protection....regards Sean
Jan 15, 2016 | Sony BRAVIA KDL-32BX330 32" 720p HDTV with...
Sony 52w5500 No image, No backlights, 13 and 14 blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 27, 2014 | Sony KDL-52W5500 52 inch Multi-System Full...
Sony Bravia KDL 32BX300 Error codes
Five blinks denotes an IRK error. To detect damaged components and to troubleshoot this error, you must have sound in electronics.
May 21, 2013 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
Dec 10, 2017 | Sony KDL-32M3000 32 in. LCD Television
Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
Sep 01, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Wont turn on
It is back light inverter board failure error. Check back light inverter board in TV.
Aug 08, 2009 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Apr 29, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia XBR KDL-40XBR6 40-Inch 1080p 120Hz LCD HDTV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
