Question about Stanton ST-150 Turntable
Stanton st.150 turntable sins unevenly
I reieved a Prompt answer by Richard but it was cutoff at JUST...
  • Pennywhistler
    Pennywhistler Apr 16, 2014
    Hi jason heatley, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Sergeant:
  • 432 Answers
That is a lack of maintenainance, but your real problem is that your
voltage regulator from -24 en 24v gets to hot, since the stanton has crappy everything, where cheap build and often the components aint screw against the cooling block, so first check that and well , there about 60 crappy su\'scon caps that needs replacement. It\'s a tt from hell with the useless weight. Your system started spinning hard, cause the thermal protection started to work. Overheating, since most peoples set the start and stop torque set at the highest point, and with the small cooling blocks you get a problem and by pressing the platter, you ask for more current and that was just too much, if your bearings were that bad you assume , you have heart a lot more noice.
gr richard
Posted on Sep 07, 2014
3 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Powere input
Some ST-150's have fuses, some do not. It would be on the rear of the unit, next to the power cable. If it is not there, then it might be under the turntable platter, on the main board. Not sure if you have a US or non-US model. So check both places. If you cannot find the fuse, then you don't have one. It's not that hard to locate. If this is the case, then your power transformer probably fried and will need to be replaced. This part runs about US$40
- DJ PRO AUDIO
Posted on Nov 22, 2007
SOURCE: Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
Peace,
DJ Quartz
Posted on Feb 18, 2009
Stantonst.150 turntable platter spins unevenly
Well, you have the rotor, which has above the conus where you put your platter on. But the rotor needs to be kept in space, so it can spin,
which offcourse in the is done by (too soft) bearings, but the bottom of the the rotor(which looks the same as the 'pin' where you put you vinyl on, just leans on a piece of metal, instead of a technics where it falls in a shaft too keep it is place.
You undestnd that the strength on the bearings of a st150 is much higher, especially when scratching. Besides that, the high torque works 0,2 sec and then an optocoupler samples the speed of the rotor. And it's easy:on the underside of the rotor ,there's a plastic round disc puled over the rotor and kept on his place by a plate and 3 screws, with on the outside just
Mar 29, 2014 | Stanton ST-150 Turntable
Stanton ST 150 motor will not turn on but all lights on deck flash?
If you have misc LEDs that are flashing without due cause and a motor, I'm betting a Direct Drive motor, that won't spin, I would same you have a damaged microprocessor(computer) within your table that's bad. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 13, 2013 | Stanton ST-150 Turntable
Where do i find stanton st150 turntable parts
www.stantondj.com/stanton-turntables/st150.html
Jan 05, 2013 | Audio Players & Recorders
Stanton deck issues
Does decks are too bad build, i gave them away
Jul 23, 2012 | Stanton ST-150 Turntable
My st-150s are only producing sound from the right side
Probably a faulty cartridge. styluscity@gmail.com
Sep 01, 2010 | Stanton ST-150 Turntable
Tone arms
Yikes! I don't see a price list for that model on their web site and I wonder if it would be better to buy another table and use the broken for "parts"?
Apr 21, 2010 | Stanton ST-150 Turntable
I need replacement buttons for my stanton St150's????
http://www.djdeals.com/partsSTANTON.htm check this sight out always been able to find what i need if not listed give em a call they can help you out
Mar 18, 2010 | Stanton ST-150 Turntable
Open Questions:
Stanton ST-150 Turntable Logo
93 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
