Question about Dometic RM2652 Refrigerator
Refrigerator section gets too cold
Refridgerator section freezes food
    Top Expert:
  • Dometic Master
  • 7,228 Answers
Move temp sensor into center of coil if same replace temp sensor
Posted on May 27, 2016
4 Suggested Answers
  • 68 Answers
SOURCE: Dometic refrigerator freezing in bottom
Move your thermistor closer to the center. Your thermistor is attached to the fins on the inside of the fridge. Also turn off the fridge and take the circuit board cover off and make sure that the thermistor cable is plugged in. the cable is a 2 wire terminal will be on upper right or upper left of the circuit board just below the 6 pin connector.There is another possibility but remote. The cooling unit may be getting ready to stop working. Have had many customers tell me that the fridge started freezing up and a few days later quit working completely.
Hope this helps you.
Posted on Mar 20, 2009
  • 10865 Answers
SOURCE: refrigerator gets too cold and freezes all the food
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Posted on May 26, 2009
  • 827 Answers
SOURCE: the food in the refrigerator
perhaps try using the adjustment the opposite way -- to be sure you are not going cooler, instead of warmer for your adjustment?
Bets regards
Ck
Posted on Jan 17, 2011
My refridgerator is freezing
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 29, 2011 | GE Profile Arctica 25.4 Cubic Feet...
The refridgerator is not getting cold
sometimes when the air flow is restricted cold air migrates back into the bottom of the fresh food side and could freeze the dispenser resevoir which is behind the crisper drawers. Also, just defrosting the freezer is only treating the symptom. Something malfunctione to allow the frost to build up. Either the heater, defrost limiter or defrost timer.
May 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Amana Refridgerator freezes in the refridgerated cavity.
Many Amana refrigerators have something called an auto damper. It has a thermostat coil on the side of it and as the temps get colder the damper door closes. If the thermostat on the side becomes defective then the damper door will remain open or shut. If it remains open the food in the fresh food compartment will get so cold that sections will freeze. If you could send the model number of your Amana I may find a service manual with instructions that tell you how to test by removing and dipping the thermostat into warm or cold water to see if it is working properly. I will be here in and out to my other websites but would be happy to assist you and resolve this problem. Thanks Sea Breeze
Jan 21, 2010 | Refrigerators
Freezing items in refridgerator
make sure the air passages are not blocked with food produts the other fix might be to un plug refrig and let it defrost for a day make sure you leave doors open
Dec 31, 2009 | GE GSS25LGM Side by Side Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator side of my refridgerator keeps freezing my food
The problem may be low gas or it may be the thermostat is set too low.  First, look at the possibility that you may have the food partly blocking an air channel which is where the very cold air is coming from..  Fridge side should read about 40 F after the door is closed for about an hour.  If colder, adjust.
Nov 15, 2008 | Refrigerators
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Dometic RM2652 Refrigerator Logo
22 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
