Question about Brother Office Equipment & Supplies
Arris router the arris wirless connection will not connect to my brother printer
  • 320 Answers
SOURCE: Printer goes offline
all you people are complaining that the printer goese off line wrong all brother printers go into sleep mode when not used for a extended period of time, usualll by pushing any key it will go on line
Posted on Jan 24, 2009
SOURCE: Brother MFC-7840w wireless printer won't connect to network
Ignore the instructions that come with the printer, choose Open System, then choose WEP, enter, and it hooks up. Thanks to the above posters for this solution.
Posted on Oct 18, 2009
  • 13 Answers
SOURCE: No IP address on Brother Printer
Hi, I am assuming that it works whn it is connected directly to your system, as you told that you got your printer replaced. And as you may know that connecting through CAT5 cable is the RECOMEND way..but thats what every1 else tell. So now, the 1st doubt that comes in my mind is about the OS you are using. The model you are using is compatible with Windows, Mac & Linux.
The 2nd possibility rises have you installed the appropriate driver for the printer you are willing to use and check your wireless settings too.
Now the 3rd possibility is that maybe there is something wrong with your router. Maybe you should make sure that the router is working properly.
Posted on Nov 26, 2009
SOURCE: Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Posted on Jan 11, 2010
  • 5 Answers
SOURCE: Can not connect to personal Wi-Fi network
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Posted on Jun 25, 2010
Cant connect modem to new wireless brother printer
It is best you contact Arris support. Mark Motorola Mobility Support ARRIS
Jun 17, 2014 | Motorola Computers & Internet
NEED SECURITY CODE FOR WIRLESS ps3 CONNECTING TO XFINITY GATEWAY
If you are connecting to a router(gateway) that has wireless security enabled you will need to enter a security code on your PS3. I wrote a tech article which explains how you can obtain this security code, or if need be, set one up. Click link - How to obtain router security key,password
-G33k
Sep 28, 2011 | Arris Touchstone 450a (CM450) Modem
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Nov 25, 2010 | Brother MFC 490cw Color Inkjet...
Im trying to connect my printer to my desktop,but dont know how
Okay
Most of these printers come with a USB cable. You would plug that in to your computer.
Then you take the cd that came with it and install that.
Now if your going wirless your going to need a wirless router and a wireless computer but you still install the cd.
i hope this helps as it was FREE. Please do leave psotive feedback and ratings for your free answer today!
Mar 05, 2010 | Brother Multi-Function Center MFC-240C...
How to hook up to a ARRIS router with comcast
All I did was put a spliter at a the end of the phone line that plugs into the modem. Next I ran a line to the arris and another to the fax machine off the spliter. Very simple.
Jack
Dec 28, 2009 | Brother MFC-845CW multi-function...
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
Struggling to connect my MacBoo pro to a printer connected on PC
is the printer connected to a router or base station wirelessly?
Jul 08, 2009 | Apple MacBook Pro Notebook
I have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
Feb 15, 2009 | Arris Touchstone 450a (CM450) Modem
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
