Question about Saeco Vienna Espresso Machine
Leaking Saeco lpus vienna machine
My machine is leaking from under the tray, I believe it is clogged. when I take out the brewgroup I see that the little pocket behind it where the water spout that links to the brew group is filled with sludgey/water espresso. I tried cleaning it out but it is still leaking. After I scoop out as much as I can (I have done this 3 times now over the last few months) the steam wand leaks for about a day or so after then stops. How can I unclog it?
Keep cleaning...make sure that run off spout the leads to the tray is 100% clear. Run water through it (with a sponge for example) to make sure you get all the sludge out. Careful about what sort of coffee you use. I have had bad luck with Illy coffee unfortunately.
Posted on Apr 02, 2014
Testimonial: "the part that is filled does not come out of the machine and seems impossible to clean out.."
JohnnyBeans
  • 223 Answers
SOURCE: Clogged Saeco Vienna de Luxe
Grinder sound like it is grinding to fine. Increase the grinder size. Remember to only change grinder setting when the grinder is spinning.
Hope this helps!
Posted on Oct 12, 2007
mirran
  • 515 Answers
SOURCE: Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Posted on Aug 06, 2008
  • 2039 Answers
SOURCE: Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Posted on Jan 11, 2009
SOURCE: Saeco Odea Giro - Clogged and coffee come out in water tray....
This has happened to our machine that we use for our youth group. We sent it in and they said it was clogged also. Not having a clue what they meant. It happened again and I figured it out. When you remove the brew group there is a hole just above it that dispenses into the brew group. Make sure it is not clogged. Give it a try Good Luck
Posted on Apr 06, 2009
EsWorld
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
Water leaking under the machine
Take a look at the little spout area that pours into the water tray. It can get clogged with coffee grounds. This was our solution with one machine. But with another, the water was actually leaking out the back and was the result of a dying boiler assembly.
Dec 12, 2012 | Saeco Vienna Plus Espresso Machine
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna coffee when the machine starts the coffee dispensing
Is it leaking only when brewing coffee ?
If not I would check the seal under the water tank (Part #NM05.006)
If so, I would check the following:
1- The water input port on the back of the brew unit (looks like a smoke pipe) might be clogged
2- The o-ring of the water tubes coming in and out of the boiler.
Jul 30, 2010 | Saeco Vienna SuperAutomatica Coffee...
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Resover leaking
The easy fix for leaking under the machine is check to see if the drain is clogged. Open the front and remove the brew unit. You will see a small hole that will drain the excess into the Plastic tray. Usualy I find Coffee grounds clogging the drain hole. Use Pipe Cleaner , Q-Tip to clear the drain hole. you can also wipe out from the other side with paper towel or Q-tips. once the clog is clear. Flush our with water.
Feb 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Water Leaks from bottom of machine as coffee is dispensed?
I had this same problem. Open the front door, remove the dreg drawer and then remove the brewgroup. In the back you will see a pipe sticking down with an o-ring gasket on it. Below that is a channel and a little opening where rinse water is supposed to flow into the front drip tray. It gets clogged with grounds pretty easily. I filled a hose with some water and stuck it down there and blew through it until you can see water come out the front hole. It's a little hard to describe but I hope this fixes your problem, it did for me. I just have to do it once every couple months.
Dec 07, 2008 | Saeco Vienna Digital Coffee Maker,...
Leaking water
Take out the brewing unit and look in the chassis behind where the brewing unit was, you will see a little hole, put in your finger and make sure the hole is clean.
Have a nice day
/Mirran
Oct 20, 2008 | Saeco Vienna SuperAutomatica Coffee...
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Espresso Machine Logo
56 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
