Question about American Water Heater s PGC3-50130-2NV Polaris High Efficiency Natural Gas Commercial Water Heater 50 Gallon
Why is Yellow hot water coming from Polaris HE ?
Drained and refilled same problem.
  • American Wat... Master
  • 3,382 Answers
Because yellow water is probably going in. It is probably rust from iron pipes or hard water. It could be sulfur. This could happen with a well system with a water softener that has failed or non existant. I do not think it is but it be your tank failing. How old is it? They do not last forever.
Posted on May 03, 2014
Hot water immersion tank. Electric Now there is chugging on coldfill after I turned off mains supply and ran hot water taps to drain off supply to fix a tap
If you turned the electric off before draining, Air gets into the system. It will sound funny untill all the trapped air gets "washed" out of the system. If the electric was left on when refilled, you may have a steam generating situation, causing the chugging.
Mar 26, 2015 | Water Water Heaters
Drained my water heater, now I seem to have a vapor lock. how do I fix it
Open a hot water faucet and let it run until steady water flow without air comes out.
Feb 11, 2015 | Water Water Heaters
Egg smell from hot water
You either have water with a high sulfur content or need to flush your heater. you should flush your heater every year anyway. you can turn off the water and electric to the heater. and totally drain the tank when it is totally drained add more water and drain some more. then refill the tank and run a hot water faucet the tub is best to eliminate any air in the system then turn the electric back on this should solve the problem if it does not you probably have sulfur in the water and would need water treatment or filters to help
May 06, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need to buy American Water Heater Polaris, 6903768
Make sure you install it correctly. If not can cause exhaust leak and destroy everything in the blower compartment. I have over 450 Polaris heaters installed. "Read the instructions". Depending on which burner gasket you have determines if you will need to use the provided gasket. If the gasket is a graphite type, you need to check and make sure the surface where the hot surface igniter seals against it. The gasket can be missing some pieces, so check carefully. The bracket "must" be installed properly. Again the instructions with the igniter show the correct installation.
Dec 13, 2013 | American Water Heater Polaris, 6903768,...
Popping noise in water heater. What is it and how do I fix it?
What is probably happening is that you have a build up of minerals on inner tank lining and when unit is heat it expands the tank and the deoosits at a different rate which is what is causing the popping noise.
I would turn power off to your heater and hook a garden hose on to drain valve.Route hose to safe area as the water being drained will be hot. Open drain valve and see if you can get it draining good.If it is then shut off water supply to heater and open hot side of faucet nearby to prevent vacumn from slowing down draining. I would drain as much as I could then close drain valve and faucet and refill tank. I would do this several times to try to get all sediment flushed out.Hopefully this will help with your noise and make your heater last longer and work more effceiently. Good luck and thank you.
Feb 13, 2011 | RELIANCE ELECTRIC WATER HEATER
Drained water heater but forgot to turn off heating element. was on for about 12 hours
there is a possibility that the heating element is now burned up, you can refill the tank and try to heat water,, if the water is not getting hot then I would say that you need to replace the element. also check the circuit breaker and wall outlet for power just incase the element did blow the fuse.
c...
Dec 31, 2010 | RTO Atwood Water Heater - 6 Gal LP
No hot water to shower since new rad was added
take the shower head off and make sureits not clogged,, if it's not then valve has dirt in it you need to take the cartdrige out or the stem depending on the diverter and clean it out, but it does appear to be dirt, maybe solder got into the water line and came up there
Feb 19, 2009 | RTO X-40 High Output On-Demand water...
White sediment in the hot water
replace heater-have u ever drained heater?turn off water supply-drain heater .try this a couple times.if u replace heater put water filter on incoming water.
Jan 07, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
American Water Heater s PGC3-50130-2NV Polaris High Efficiency Natural Gas Commercial Water Heater 50 Gallon Logo
Top American Water Heater Water Heaters Experts
Gil Shultz
Gene Haynes
David Spradling
David Spradling
Are you an American Water Heater Water Heater Expert? Answer questions, earn points and help others
