Question about Garden
Running wide open
I was cutting grass . Running fine all of a sudden it started running away like IDL 10,000 RPM
  • 151 Answers
Throttle spring came undone or something is stuck in the air gate/cetrifugal lever that controls the throttle.
Posted on Apr 01, 2014
4 Suggested Answers
  • 7 Answers
SOURCE: Lawn mower runs choppy. Up and down. Still cuts
check to see if your blade is bent.
Posted on May 08, 2012
  • 6468 Answers
SOURCE: lawnboy model 10525 ,irregular rpm when cutting grass
needs a good carb cleaning
Posted on May 12, 2012
  • 6468 Answers
SOURCE: I have an MTD Yardman 12a-44mc055. Suddenly, the rpm of the blade decreased, even at full throttle. It has very little power. Does not cut grass and the self propel mechanism does not work. Any though
is the blade loose?is the pulley key way sheared as well as the key on the flywheel
Posted on May 14, 2012
Honda hrb536c
Tony you may be cutting too much too soon. Try running over the grass slowly with the back guard opened slightly so any grass can still spill onto the ground. When youv'e done one run put the grass box on and go over half a width of the mower at a time but start on a reasonable height.
Apr 22, 2014 | Garden
Why does the mower blow out chuncks of grass, i am not cutting to low? ive only usewd it 22 times
1. Sharpen the blades
2. Cut when the grass is dry
3. Ensure the belt to the blades is not slipping.
4. Clean the underside of the deck after each use, use a scraper if you must but keep the buildup to a minimum
5. Run the throttle wide open during cutting
Jun 16, 2010 | Toro 42'' Zero Turn Lawn Mower Trailer...
How do you set the carb screws on a stihl d12 avt chainsaw? how many turns for high an low?//?????
I would start by opening each 1 turn. Then 1/2 turn until I got it running. While running, set the low by turning the screw out until the saw starts to slow down. Then turn in until the same thing happens. Set the screw about 1/2 way in between. Do the same with the high but do it while running at a higher RPM. Do not run it wide open unless you have the chain in wood, cutting. Good luck...Lee
May 28, 2010 | Oregon Scientific Complete Carburetor for...
Bike cuts out at 10,000 rpm
Eventually it won't start at all if you keep redlining her like that. My advice to you is get a faster bike.
Jun 20, 2009 | 2005 Honda CBR 125 R
Harley engine Running high RPM, the engine runs fine for a while and then it starts racing at high RPM. If I shut it down and start it up again it's fine for a while. This is a 96Road King with fuel...
The problem is an air leak leaning the fuel mix. The idle speed starts going up a ramp until it is wide open. The valves no longer seating well is a possible cause as is air manifold gaskets, rings and a cylinder head not torqued down tight.
Apr 22, 2009 | 2000 Harley Davidson FLHRCI Road King...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
