Question about Cell Phones
Caller id does not show phone number
Phone number block to user
SOURCE: caller I.D wont show...
try to copy all the contacts on a paper then delete all the ph book contacts and write them again make shure that when you write the phone number with the area code if its like that on your ph book
Posted on May 18, 2008
SOURCE: caller ID
Make sure that the number stored in the phone is the same number you get when they call. I had the same problem and i noticed that all incoming call has a 1 in front of it because it is the areacode of US.
Posted on Feb 17, 2009
  • 3 Answers
SOURCE: CECT KA08 Caller ID/Msg ID
Hello, I had the same problem, but i figured out how to get the callers id/information. On the main page select Call Center>>Call History>> SIM1(or whichever you are using)>> and select either the Missed/Dialed/Received calls. Lets choose Dialed Calls for now. Select a phone number that you recognize>>select OK>>Options>>Save to Phonebook. In here you will create a new contact. Make sure you delete this old contact information from your phone book. (so you don't have doubles if already saved to your contact list). Now you can go to your main menu again and select the phone book option. Select the contact you have created and add a photo and ring tone you like. Now when you get a call you get their photo and rign tone. For sms you get only their name, but thats good enough for me.
Posted on Jun 28, 2009
  • 13 Answers
SOURCE: sci phone sms caller id not working. Only the
When saving a contact to your phone book for some reason you have to save the number with a "1" in front of the area code and number or it will not register as the contact calling. I would save a number and have them call or send text but it just kept coming up as the number itself and not their name. I changed the number with the 1 in front of it and it worked just fine.
Posted on Aug 24, 2009
  • 20 Answers
SOURCE: LG VX5400 only shows No ID
Phone settings then Display you should find caller ID on or off.
Posted on Jun 04, 2010
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Droid z992 shows restricted number rather than my name on recipient phone. How do I fix this.
Caller ID blocking feature may be on go to Settings and then tap on Call on a android phone
From there, tap on Additional Settings and in there, tap on Caller ID
just set the Caller ID to show Number" and it will be unblocked
Oct 03, 2015 | Cell Phones
How to block calls on home phone that show up as private caller
You would have to subscribe to that feature from your local phone company, then when a number like that calls they will get a recording that states you do not accept blocked calls...
Jun 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
I have activated the caller id block for my outgoing calls. How do I reverse this process so that my number shows up to the people that I call?
The procedure depends on your phone company, not on your phone. With some phone companies, for example, dialing *82 before dialing the phone number will deactivate caller ID blocking for this call.
Please contact your phone company for full instructions.
Apr 03, 2012 | Uniden DECT 6.0 Cordless Phone ID
On my Uniden Cordless Tru9380 Series phone, how do I use caller ID ? please give deailed instructions as I've had it for 4 days & still cannot figure out how to do it. Help will be greatly...
Caller ID with Call Waiting is available by subscription from your Telephone provider. With this service, you will be able to view incoming caller information while on a call with another user.
This will allow you the ability to select to talk to this user and put your existing party on hold or make the decision to ring them back.
But, you must contact your Telephone provider and subscribe to the service.
Here is the link for the User Guide: http://www.uniden.com/pdf/TRU9380-4om.pdf
Remember, If you subscribe to Caller ID from your phone company, your phone will show you the caller's phone number and name (if available) whenever a call comes in. If you subscribe to both Call Waiting and Caller ID, the phone also shows you the name and the number of any call that comes in while you're on the line.
Jan 15, 2011 | Uniden Cell Phones
How do i block my number on an outgoing phone call?
i found the answer at http://support.sprint.com/support/article/Block_your_Caller_ID_on_your_outgoing_calls/case-wh164052-20100907-100732?&INTNAV=SU:SP:HDIB
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
Jan 07, 2011 | HTC Snap S522 Cell Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Blocking of caller id
I can help you with that, if you dial *67 and then the phone number, for example ( *67-715-392-0123 ) it should block your phone number from comeing up on caller id...........Hope this helps........
Jun 27, 2009 | Nokia N70 Cellular Phone
Caller ID??
the phone is not equipped to handle caller ID
Oct 17, 2008 | GE RCA 4-Line Speakerphone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
