Question about Samsung Cell Phones
My sght599 won't connect to a network
I rebooted my sght599 and I can't get it to connect to a network
    Problem Solver:
  • 9 Answers
Try to reboot again. When you reboot the first time network driver didn't load properly. After second reboot is a big chance it will work or you just need to reset the network parameters (choose the right network from the list of available networks and fill in the password. If you still have a problem check your wireless router if there are available IP addresses in the DHCP server setting. If in the previous step you don't see the available wireless networks that means your devise network driver is corrapted. Your last option is to go to settings and reset to factory defaults. Back up all your data to a computer before you proceed.
Konrad
Posted on Sep 23, 2014
Sght599 backup pin
Press volume up, menu and power buttons. When Samsung logo appears let power button go till a dumping of menu appears. Now scroll with volume down key and select wipe data to factory reset your phone. Note, you will loose your personal contacts, photos, and any file on phone but problem solved.
May 08, 2014 | Samsung SGH-T499
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gerardo_bdb2f65bdb2cdd4d
Feb 21, 2013 | HP LaserJet 2840 All-In-One Printer
Won't connect to router
Shut down compter, unplug router and the ISP modem, Check ALL cables and reseat ALL connections, plug in the ISP modem allow it to selftest, plug in the router allow it to selftest. Reboot the computer, plug in Ethernet cable.You didn't give much info to work with. Wired? Wireless? Does it connect to other devices? What is the OS? Vista? Is this a recent issue? What it the router Make ,Model? Open the Network and Sharing Center, Manage Network Connections, Is the Ethernet Adapter enabled?
Jan 07, 2013 | eMachines ET1161-03 PC Desktop
Network won't connect
As you may guess, I'm going to need more info to help you. What network? Won't connect to What?
Nov 18, 2012 | Computers & Internet
Sapido firmware problem
Connect to it with a ethernet cable and try again. Since you reset the device it won't have your wireless network configured. Since you are no longer connecting to it via wireless, you are getting the 169... address. Once you connect to it with the ethernet cable you should get an address from the device. Then go to http://192.168.1.1 and user the user name admin and password admin. You should be able to reconfigure your wireless network from there. http://www.sapido.com.tw/EN/faqrb1632.htm
Oct 16, 2012 | Sapido RB-1632 3G/4G Mobile Hotspot and...
Router won't recognise my new Kindle
First try rebooting the router to see if it "see' the kindle. Make certain use are using the correct network password/key - it is case sensitive. Does the Kindle connect to other WiFi networks? If not the Kindle may be the issue
The ultimate answer is a factory reset of the router.
Dec 16, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I just purchased this treadmill. The internet was working on it. I needed to upgrade the firmware; but it wasn't allowing me to do so. I then moved the positioning of the treadmill. I still have a...
Please in the section open connections network give to repair, and the system will repair.
If the problem persist reboot the Modem-wireless router again, and see if the signal is coming more Strong.
Reset the Modem in the small hole, with some pencil introduce the pen and reset it
Retigh the wires coming from your Modem Wireless router. And finally Test again if is working. sincerely.
Sep 22, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
Ethernet won`t start
you will need to rinstall its drivers, insert your motherboard CD and reinstall the network adapter. then reboot
Mar 22, 2009 | Intel Motherboard
Cell Phones Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
