Question about BenQ Televison & Video
Vga Connector requires constant pressure, otherwise projection has a green-yellow hue. would resoldering the reverse side of the built-in female connector solve this problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
There might be a broken pin . better replace / purchase a new vga cable
Posted on Aug 22, 2014
SOURCE: Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Posted on Nov 20, 2008
  • 668 Answers
SOURCE: color is gone, hue is greenish yellow
It sounds like the Optical Block is causing the problem. Due to the cost of the part, ( around 600.00), I would contact Sony at 1800-222-SONY and see if the would be willing to help out with the repair cost.
I hope this helps,
Skyassoc
Posted on Oct 30, 2009
  • 556 Answers
SOURCE: my sony kds-60a2000 has green tint. can't adjust
You have a bad light enging call sony see if it is on the extended warranty list.
Posted on Dec 01, 2009
jan mczeal
  • 632 Answers
SOURCE: how to get laptop connected with vga connector to
Unplug the television. Connect the VGA compatible monitor cable from the laptop's VGA monitor Output to the VGA Input on the back panel of the television. You will need a splitter to connect the audio cable from your laptop to the VGA Audio Input on the television. Never mind if you have speakers connected to your computer.
Press the Device button on the remote control or on the television front panel to display the Device Selection Menu. Select the device you want to view, in this case VGA. The only compatible resolution is 640X480 at a sync rate of 60 Hz.
Do not leave stationary or letter-box images on-screen for extended period of time to avoid uneven picture tube aging.
Posted on Jan 23, 2010
Zephyr0u812
  • 27 Answers
SOURCE: Hey everyone. I have
You can try adjusting the color output. There are two ways to do this:
1) In the service menu (I don't know the codes or parameters...) I will not cover this for lack of info.
2) Via the focus block (Very touchy and difficult to get the mix right again if you get too far off)
If you take off the front cover there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need more red in the mix or just less blue and green. There is a screw for each color. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Barely turn the red up.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn andy of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Posted on Apr 19, 2010
Testimonial: "Thanks, everything worked fairly well. I'm still having a very small convergence issue on the bottom left of the screen. Magic Focus isn't cutting it"
Can this laptop be connected to an lcd tv?
You should definately use the VGA connection if your TV supports it. You'll get much better resolution than you would from the S-Video.
Mar 15, 2011 | Computers & Internet
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1996 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1996
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: Retain Keyless entry with secondary Harness Listed Below
Additional Accessories:
Metra Brand Dash Kit: 89-30-7891 - 99-7891 - 99-7898
Metra Brand Wiring Harness: 70-1720 W/Keyless Entry # 70-1720T
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Ignition 2: Yellow - Ignition Switch Harness
Accessory: White/Black - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Blue/Black - (-) Driver's Kick Panel
Parking Lights: Red/Black - (+) Driver's Kick Panel
Head Lamp: Red/White (L) Red/Blue (R) - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Above Fuse Panel
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Orange - (-) Module Behind Radio
Horn: Grey - Steering Column or GREEN connector behind radio
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : Blue/White - Driver's Side Dash Footwell, Grey connector.
NOTES: PPM - 4000PPM
ROSTRA Control Arm # 250-3421/250-1483
ROSTRA Throttle Adapter #250-4249
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This...
1995
Ground: Black
Dimmer: n/a
Front Speakers:
Left Front (+) Blue/Green
Rear Speakers:
NOTES: - none -
Metra Brand Dash Kit: n/a
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
SONY KDF42A10 COLOR OFF
describe the yellow or green hue, is it eaven all over the screen or does it look like it is more noticeable on some portions of the screen. could be that you might need the light engine repair.
Jan 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My screen has a green hue and cannot seem to correctit is a protable dvd with lcd screen
One of the possible things:
a loose/bad/dirty connector contact or a bad solder contact inside the case (possibly the LCD screen connector at either side). This may show up as the problem you're having with your unit. Checking and/or cleaning/resoldering the connector pins might solve this.
It may also turn out to be something else (like a bad output from a chip or a bad component inside or near the video section, which might require component replacement.
regards
3rq8 (Triarcuate)
Jul 22, 2009 | GPX PD808B Portable DVD Player with Screen
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This...
1994
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1993 Honda Civic This...
1993
Constant 12V+: White/Blue
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Orange/White
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
When I plug in VGA there is a green mask or Hue, over the whole screen... I tried changing the settings but its not controllable with colour settings
I would try a different VGA cable, if you are using a VGA to component cable (VGA on one side and red, blue and green on the other end) you can just have the cables mixed up, make sure red is with red and so on
Aug 18, 2008 | Televison & Video
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
1992
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Televison & Video Logo
27 people viewed this question
Top BenQ Televison & Video Experts
Lawrence Oravetz
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
