Question about Frigidaire GLTF1670A Front Load Washer
FRIGIDAIREGLTF1040AS0 TUB SEEMS TO BE LOSE AND BOUNDES WHEN SPINING
    Top Expert:
  • Frigidaire Master
  • 35,597 Answers
Tub support bearing failure is common in front loaders.
Posted on Apr 01, 2014
LG 7.5 wd-10165fu when spining on 1000 makes a noise like its touching against the side of the machine
If tub is banging around it could be dampers, but if it's a scrapping sound then something is caught in the inner tub and at hi speed it touches the outer tub.
Apr 23, 2017 | LG Washing Machines
Tip
Washer not spining Top loader part I
There are a couple of key parts in makeing the tub of the washing machine spin and here are some of the ways you can test whats wrong with your washer and why it is not spining. The most popular for all direct drive units is of course the drive couple which is the small plastic and rubber piece that attaches the motor to the transmission these tend to break more often then any other piece due to when made for manufacturers they do not have any metal on the three pronged connector nor in the center the replacement coupler does come with a metal washer in the center which prevents the actual spining stress caused on the piece to break the small arms that come off the connector. the best way to test for the coupler is by visual inspection so remove the cabinet, pump and motor and assure that the drive couple has not broken at all. if you need a video of how to replace the drive coupler click here http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5501893181&kw=whirlpool%20coupler&gclid=CMSzgdOGvqgCFUSo4Aod1SgCqA
Another problematic area would be the clutch that is connected to the transmission. One of the easiest ways to check the clutch is to set the unit to spin with no clothes on the inside. While the unit is spining use the palm of your hand and press your palm against the inside wall of the inner tub if the tub slows or stops this would mean that the clutch is worn or defective and would need to be replaced. Here is also a video of how to replace the clutch click here http://www.youtube.com/user/RepairClinic?v=tVc6SZ2DD4U&feature=pyv&ad=5454782141&kw=washer%20clutch&gclid=CKut8bSGvqgCFYFM4Aod4n2trQ
there are also other parts that cause the unit to spin such as the motor, transmission, and timer and these will be discussed in part 2 So look for Washer not spining Top loader part II Thanks again for using Fixya
on Apr 28, 2011 | Washing Machines
My Washer Baskets is leaning to one side when washing and spinning
Hello penpoint1959 - The tub is stabilized in the center with multiple springs which attach to the base of the washing machine and the frame of the tub. If one of the spring(s) is loose or broken, this may result in the tub being off center. Other possibilities are, the unit is not level and the load of clothing is not balance evenly in the tub. I personally first verify that the unit is level and the unit is being loaded evenly. If correct, and if I was in your position I would contacting a certified technician to move forward accurately and to assist with the repairs.
Feb 17, 2013 | Frigidaire FEX831CS Top Load Stacked...
Rotator seems to slip and only work part-time. Also tub won't drain.
ok first do you mean the agitator if this unit that we are talking about is a top load washer then you would most likely need to replace the agitator dogs here is also a video of how to replace the agitator dogs as well http://www.youtube.com/user/RepairClinic?v=0GQh8JLqVv8&feature=pyv&ad=5457341621&kw=agitator as to the tub not draining this would be most likely a clog where you would have to check the pump and the lines going to the pump as well to assure that there are no objects jammed in the the drain system here is a link showing how to replace the pump you would only do this if the impellar on the pump was not spining and you can actually remove the pump and see if the the impellar is spining which would tell you if your pump is good or not http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw&feature=pyv&ad=5457341861&kw=washing%20machine%20pump if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
May 29, 2011 | Washing Machines
My washer started by spining faster then normal and then it started makeing a loud knocking noise and now sounds like metal rubbing metal. Everything else works fine just can't spin anything.
SOUND LIKE INNER TUB AND BEARING AND SUPPORT SHAFT...# W10250573 $364.00 INNER TUB AND SHAFT..REAR TUB AND SEAL#8181912 $224.00 VERY TIMELY AND EXPENSIVE REPAIR CHECK WARRANTY ON WASHER
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Shakes during spin cycle like off balance but its not , also makes a loud clunking sound wont trip out the whole tub assembly seems loose
it probably is lose sounds like the balance springs on the bottom of the tub either come off? or are broken
Jan 14, 2010 | Washing Machines
My GE wjrr417og2ww the tub seems lose and with heavy loads the washer is making noise. Has a strut or spring come off?
make sure basket is tight to tub/ transmission (hub nut is not loose). remove front cover (two clips between front and top), use putty knife to release, pull forward at top then lift out. check mouting of hangers, also look at rubber straps between tub and frame at top (4). the straps limit tubs travel from hitting sides
Jul 05, 2009 | Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
My washer wont empty out while spining.
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Aug 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire GLTF1670A Front Load Washer Logo
18 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
