Question about Hammond XK1 61-Key Modeling Organ
Dead key on xk1 My xk1 has a dead lower C key no sound
I have a dead lower C key
The lower keys wont work without harmonization
Sounds like you have the accompaniment function selected. Find the button on the front panel and deselect it and you will get full control back
Feb 01, 2014 | Casio Keyboard Power Adapter
Won't load to default
Hi Lloyd,
The introduction in the manual warns that you should ask your dealer or store in order to change the batteries. I'd suggest seeing if they have any advice.
That said, how are you trying to default the settings? I've copied the two ways below. Maybe try whichever one you haven't yet. I hope this helps.
Manual: http://hammondorganco.com/wp-content/uploads/2011/03/XK-1manual.pdf
Default #1:
In this mode, you can return entirely or partially to the default setting as set at the factory.
To locate this mode:
Touch the [MENU/EXIT] button for the MENU display, select PAGE D by the [PAGE] button, and then touch the [3] DEFAULT button. To initialize each parameter, touch the button and then [4] OK
1. ADJUST PRESET
  • Initializes the content of the Preset Key [B].
  • If the Drawbar Control mode is at "UPPER A#/B", the content of [A#] is also initialized.
  • If you do this operation before you start a new setting, you can start from the factory
  • setting.
2. PRESET
  • Initializes the content of all Combination Presets.
3. GLOBAL
  • Initializes the Global Parameters such as Master tune or assignment of the Foot Switch.
4. LESLIE
  • Initializes the content of all Cabinets.
5. ALL
  • Initializes all parameters of this keyboard.
  • If anything caused an unstable trouble on this keyboard system, the trouble would be cleared.
Default #2
Please perform the following steps to reset the XK-1 to the initial default setting.
1. Switch off the power of the XK-1.
2. Hold the [REC/JUMP] Button, and switch on the power.
3. Continue to hold down / Keep pressing the [REC/JUMP] Button until "Loading Default..." appears on the Display.
4. After 5 seconds if everything is in order, PLAY Mode appears on the Display. (Completed)
Dec 20, 2013 | Hammond XK1 Pro Drawbar Organ
Load to default not working
Did you follow the instructions from the manual? If yes, at what point did this process fail?
My m3 makes no sound starts and runs perfect tubes are all lit
Sometimes people are fooled because some tubes have TWO heaters in them and you have to check that BOTH are lit. Your first thing is to get a schematic. Try the "Captain Foldback" site for Hammond schematics. You can find it with Google.
Sep 09, 2011 | Hammond XK1 Pro Drawbar Organ
When I turn on my xk1, I get no sound, no response from any buttons, keys, drawbars or knobs. I have tried the factory reset and it doesn't work either. What else can I do before I return it to the...
Take it to the store and have them test it... don't be surprised if there is a simple thing that has been overlooked. If it doesn't worked there, it needs to go in for servicing so that is the logical course to follow anyway.
Aug 06, 2011 | Hammond XK1 Pro Drawbar Organ
I have a Hammond XK1, I plug it in and everything is fine. Once I turn on the recessed ceiling lights with the three rotrary dimmer switches, I get a loud scratchy/hummming line noise through the amp,that...
It is probably so kind of interference from the rotary switches. It is in the shielding of the Hammond organ. You might try some aluminum foil around the unit certain areas at a time which will give you an idea if it will help and what areas need to be shielded. If that does the trick you install the aluminum foil shield inside the chassis. Hope that helps. Let me know..
Jul 25, 2011 | Hammond XK1 Pro Drawbar Organ
MY WIFE WAS PLAYING THE ORGAN THIS MORNING, SHE HEARD A SNAPPING SOUND AND THE KEY BOARD WENT DEAD UNTIL YOU GET TO THE NEXT TO THE LAST C ON THE LEFT SIDE OF THE KEY BOARD. ALSO THE VOLUME LOWERS ITSELF...
Servicing is obviously required. By the symptoms, I think a bad electrolytic capacitor is the likely culprit. One other possibility is contamination, including an insect has gotten into the works and causing a short at some point.
Nov 15, 2010 | Music
G key not sounding
If it is a single key, then the key contact either needs cleaning or there is a crack in the circuit board with the contacts. These likely are conductive rubber contacts. Take them apart and clean with 99% isoprophyl alcohol. They are usually a black rubber "pill" in a silicone rubber dome that is pressed onto traces on a circuit board. Clean both the pi;ls and the circuit board. Do all thekeys at the same time to avoid having to take apart to do others later.
If ALL G sharps keys are dead, then either a wire is broken or circuit board connector or a crack exists in the board. Cracks in the board is USUALLY fatal.
Jul 07, 2009 | Korg Pa800 Synthesizer
Hammond XK1 61-Key Modeling Organ Logo
14 people viewed this question
Top Hammond Music Experts
drivealot
rhodesworks
Are you a Hammond Music Expert? Answer questions, earn points and help others
