Question about Dometic Rooftop RV Air Conditioner
Freezing rooftop a/c
My rv rooftop a/c freezes up especially at night,but now it started doing it during the daytime,and its 90 degrees outside.
  • panilling9
    panilling9 May 11, 2010
    is your filter clean,?
    is your evaporator coil clean?
    does your airflow seem normal?
    you may be low on refrigerant?
  • 29 Answers
My home unit was doing that because it was low in freon and needed charged.
Posted on Jun 15, 2009
Coleman 8000 compressor only comes on and cools when cool outside like in Am or late pm
Clean the coil inside and outside. try putting it in a window on a shady side of the house. I worked on a outside unit wher it was 90degrees outside but 107 degrees where it was in a hot location, close to road on sunny side of house.
Jul 28, 2012 | Dometic Rooftop RV Air Conditioner
Dometic AC cycles on and off
sounds like you don't have enough of a charge in the system of "free-on". that would make the a/c cycle and cycle to try and keep the pressure up and would also contribute to the lines frosting and freezing
Jul 04, 2012 | Dometic Rooftop RV Air Conditioner
Our Dometic air conditioner freezes up & we have to shut off the compressor for a while until it defrosts.
That's right. There is no defrost cycle on a rooftop unit as they are so basic. They need a defrost regularly, especially when it's warm. Check the outside unit is clean and air gets through the vents ok.
Apr 22, 2012 | Dometic Rooftop RV Air Conditioner
Freezes up in 90 degree low humidity. is this fixable? model #620426.331
Do you have good airflow out of the inside vents? Does it run fine in the daytime then you go to bed and it's frozen in the morning? Let me know what it's doing and i'll try to pinpoint what your dealing with.
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
I just had a new a/c - heat pump installed on my 5th wheel. The a/c works well but when I turn on the heat pump it seems to blow air about the same temperature as inside the coach. I seem to hear the...
Hi; I hope You called a company that will honor any warranty on the heatpump. Sounds to Me like I would contact the original installer for more help or free replacement.Also at 55 or 75 degrees outside The heatpump should be providing toasty air. Only at close to freezing temps will You get a reduction in warm air and then the heat strips will help out then also check to see if the unit has outside air dampers and make sure they are closed..alpharome416
Feb 23, 2010 | Dometic Rooftop RV Air Conditioner
DURING DAYTIME WHEN HOT OUTSIDE 35-40 DEGREES C, AC TRIPs off
units are not able to work properly above 90, 1.0 T not go for more than 1 room. is outside of unit clean? if not turn off power to unit then spray 409 or simple green or something along those lines of cleaners on the coil part (soak it real good) it should cover entire coil as much as possible. let cleaner sit on it for about 10 minutes then use water hose to rinse as good as you can. wait about 10 minutes then try unit - so work better.
Jun 15, 2009 | Heating & Cooling
RV ROOF TOP AIR CONDITIONER TRIPS BREAKER
Possible low voltage condition would cause that kind of a problem. To small a cord without the ability to carry and maintain the voltage would cause a voltage drop. I would test the voltage supply and make sure it is within 10% of that required for your A/C to operate properly.
Jun 15, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
290 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
