Question about Viking 37 in. VGSU161 Gas Cooktop
Removing spark module viking gas cooktop
Some burners not sparking
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
Posted on Jun 11, 2014
  • 42 Answers
SOURCE: Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Posted on Dec 23, 2008
Kgt1962
  • 59 Answers
SOURCE: Only 1 of 5 burners is working on my Viking electric cooktop
By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
Posted on Mar 05, 2009
Kgt1962
  • 59 Answers
SOURCE: Viking Designer Series gas cooktop not cleaning well
I'm sorry to say that there is not a wonder solution for this. You try laying a damp cloth on the aluminum part to try and allow the moisture to soak in the clean it off.
Don't use anything abrasive as the aluminum will scratch.
  • 1015 Answers
SOURCE: viking gas cooktop vgsu161-6b sparks continuously.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Posted on Oct 20, 2009
SOURCE: My VIKING 31
I have the exact same problem, same model. Read the instructions on this website for replacing the ignitors...looks complicated, also generic to all Viking cooktops. Let's see what we response we get.
Posted on Oct 26, 2009
Replace spark module on viking gas cooktop
Lift off the burners and remove the top, you will find the igniter pack in there be sure to turn off the power first.
Apr 01, 2014 | Cooktops
No clicking noise when I try to light any burner
Check power to cooktop first to assure it is not the issue. If not the issue, the spark module is the cause of all the burners not working. If only one burners its a burner switch, if more than one burner its the module that needed replaced.
I hope this helps.
Aug 10, 2013 | Viking 37 in. VGSU161 Gas Cooktop
One burner will not light other burner clicks
Under the burners where you have the gas pipes and valves
you have only one electrical part the ignite spark module. This plastic box has
one input the power wire and for outputs one for each burner. Now you can check
if the wire going to the problematic burner is loose or cut out and fix it. If
all wires look ok then the Spark device is bad and need a new one.
Dec 12, 2010 | Viking 31 in. VGSU101 Gas Cooktop
Viking vgic3054-b left side burners do not spark right side fine
no to your comment.if all the wires look ok & the module is sparking change the wire from one that is working to the faulty one if still not working it will be the spark electrode in the burner.
Sep 14, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Dec 23, 2008 | Viking 42 in. Professional Series...
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Burners not lighting
I had the same issue and replaced the spark module myself, lots of wires and you have to make sure to label them before removal to be able to hook them back up correctly. To get to the module you need to unscrew all burners, no need to take the cover plate under the knobs. Burners remove by unscrewing center, brass nut. OEM spark module is VIKING RANGE #PA020021 U-67205-21. Go
od Luck
Apr 18, 2007 | Viking 37 in. VGSU161 Gas Cooktop
Viking 37 in. VGSU161 Gas Cooktop Logo
390 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
