Question about Helman Group RKP-630 Popcorn Maker
Need bucket sproket for ccp-510 d
The kettle sprocket or gear runs against the one attached to the top of the machine
Where or can i get parts for a popcorn cart?
I would check your local restaurant supply store. They will lead you in the right direction.
Aug 29, 2014 | Nostalgia Electrics CCP-509 Popcorn Maker
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
How to fix this problem?
See if the gear at the top of the kettle rod is "jumping" and not allowing tehe stirrer to rotate properly. In my machine, this was caused by a broken black guide at the atop the two gears. The guide is screwed into place. It allows the gear to slide in and out as you rotate the kettle, but it also has to prevent the rod from moving back and forth or the gears will slip
Sep 13, 2012 | Nostalgia Electrics Helman Group CCP-509...
Need instruction on a popcorm machine ccp509 and ccp-510. how much oil, butter, popcorn to you put in them. they came with no instruction.
CCP-509 User Manual
http://nostalgiaelectrics.com/manuals/ccp-509.pdf Instructions for use see Page 7
CCP-510 User Manual
http://nostalgiaelectrics.com/manuals/ccp-510.pdf Full instructions see Page 10
The instructions for the CCP-509 are not specific about the quantity of oil and kernels to use. The instructions for the CCP-510 are clearer, stating that for every measuring cup full of kernels ( 4 oz.) add 2 tablespoons of light vegetable oil.
Mar 21, 2011 | Nostalgia Electrics CCP-509 Popcorn Maker
The palstic piece at the top of the machine..CCP-550
Just call Nostalgia Products at 920-347-9122. Tell them you need a retainer plate. You will need the Date Code from the back of the machine.
Sep 21, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Female Old Fashioned Movie Time Popcorn Machine part of under-ket
You need a new kettle. Call Nostalgia Products at 920-347-9122.
Jul 26, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Need new cord that plugs into kernal kettle.
The CCP-510BLK will use the same parts as the red CCP-510. For replacement parts, try calling Nostalgia Electrics at 920-347-9122.
May 11, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
How to replace timing belt on 1997 kia sportage
you have 2 sprokets to worry about the top two and crank gear, the crank gear has knocht on it and index on block ( towards back of gear visible from top) place on tdc mark ( top dead center), install the timing belt on this gear first then secure it with a piece of hose or anything that fits in between housing and belt to secure belt from moving from gear) then align the right side sproket on "E" for exhaust cam at top marks on cover and sprocket, then install belt over that sprocket, finally align left side sprocket "I" for intake to the top mark and install belt not too tight or it will make noise just make sure it is firm. now to double check from left to right with you standing in front of vehicle you should have left cam sprocket with "I" for intake to the top and right sproket with "E" for exhaust to the top. having bottom gear on tdc (top dead center mark) and all marks lined up with belt installed and proper tension secured, turn engine over twice and make sure marks meet in the same place then put everything back together. ( recommend you replace both idler and tension pulleys and check water pump, replace if needed or you'll be back.- this procedure goes the same to spectra, sephia, sportage, you will not damage the engine on these vehicles if belt goes out except rio. if timing belt goes out on the rio it will need an engine, if lucky just head. recommended replacement on all is every 60k miles) goo luck tightening the power steering drive belt when you put everything back together, just use a long bar to pry and good leverage. and a second hand comes in handy.
Aug 02, 2008 | 2002 Kia Sportage
Helman Group RKP-630 Popcorn Maker Logo
Top Helman Group Kitchen Appliances - Others Experts
Tom Chichester
Duff Howell
Are you a Helman Group Kitchen Appliances - Other Expert? Answer questions, earn points and help others
