How do I find skitter? I am looking for me tv
  • 3,320 Answers
Truck doesn't hold the road on bumps. Turning on bumpy road at highway speed causes the truck to skitter. Shocks have been replaced. Ball joints?
the caster needs to be checked as well as loose steering components too much negative caster will cause this also too much air in the tires
Dec 26, 2012 | 1999 GMC Sonoma
I have an 1877 Rockford pocket watch. I can open the face and the back cover, but can't figure out how to get to the "works". There is a pushin flat lever just below the stem (when the back...
The "pin" you're describing sounds like the pin-set lever, which would be used to set the time. Pushing in the pin while turning the winding crown will move the hands forwards or backwards, depending on the direction in which you're turning the crown.
If you are trying to see the rear of the watch movement--i.e., where the balance wheel is ticking--and you can't see anything after removing or opening the back cover, you probably have a watch case with two back covers. This is not uncommon--the first cover might have engraving or a photo inside it; the second cover would serve as a dust shield. While the rear cover may screw off or be hinged, the inner cover is almost always hinged. Look for a tiny divot or imperfection in the dust cover where it does not seem to cleanly meet the rest of the case. Insert a case opening knife (or just a dull pocket knife blade) into that opening and *gently* twist. Do not get too aggressive here or you could deeply scratch the watch case and/or skitter across the face of the watch movement, significantly reducing the value of your pocket watch.
The dust cover should pop open with only a small amount of pressure. Swing it back, and admire the view of your pocket watch movement.
If none of this matches what you're seeing on your watch, follow up with any identifying language about the type of watch case that you have. Typically, the manufacturer will stamp some info inside the outer-most back cover of the watch. Note that the case maker is probably not Rockford; movements and cases were often sold separately and mated together at a jewelry store. That way, people could put a good movement in a cheap case, or a cheap movement in an expensive gold case.
May 09, 2011 | Watches
Hi...I bought a syma s018 rc mini helicopter a week ago and it was working great but now, when i fully charge it, it doesn't have enough power to lift off the ground. Is my battery defective? It seems to...
I believe the Syma S018 is the same as my Yiboo UJ417.
Mine never got off the ground out after charging for an hour.
It just skitters along the ground. Must be a bad battery. Returning it if I can.
Nov 13, 2010 | SYMA Toys industrial Syma S018 Air Wolf...
Purchased Helicopter MINI AIR WOLF Model UJ417. from RiverCenter Mall vendor in San Antonio, Texas 3 days ago, while on vacation...live in kansas.Hope i didn't get scammed. Vendor never said it would only...
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
Sep 01, 2010 | Toys
Transmission skittering, whirring, buzzing noises
Hi. I think you have a low tranny fluid level. If you never changed it, now would be great time to do so.
Apr 27, 2017 | 2002 Subaru Impreza
Tv looks fine when playing movies or Tv but looks all teac blue when using xbox360
Depending upon the signal, perhaps the convergence is off all the time, just not seen. If you can solder, try resoldering the convergence IC pins. Let me know if there is any change.
Thanks,
Dan
Sep 24, 2008 | Sony KP-51HW40 51" Rear Projection...
AC i Probs
Sounds like an AC adapter connector issue. Probably a cold solder connection. You need to completely disassemble the laptop and visually inspect this connector. Touch up the solder contacts. This should fix you up. You will need a torx 9 screw driver to disassemble the unit. Also it's imparitive that you remember the locations of the removed screws. Soldering skills come in handy too.
Nov 07, 2007 | Compaq tc1000 Tablet PC
Problem
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Oct 30, 2007 | Sony KP-61HS30 TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
