Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
I have a leak from the bottom of my freezer. IT seems to be coming from the front left edge corner. Dripping down the adjustment screw leg. I just cleared drain line so its not that again. This is ano
IT seems to be coming from the front left edge corner. Dripping down the adjustment screw leg. I just cleared drain line so its not that again. This is another one. can't see where it is starting just where it shows up. I have looked all underneath and can't see its origin anywhere. Is there anything in the exterior wall or door that could leak?
  • 151 Answers
That's where the drip pan is for the underside models, other than that it's likely a leaky door seal on that side or the case heater went out letting it sweat.
Posted on Apr 01, 2014
How can I adjust an upright freezer door ?
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Sep 24, 2014 | Crosley CFUM21LW 20.6 cu. ft. Upright...
My Admiral side by side has a leak from the bottom of my freezer.
check your door gasket for air leakage, it sounds like condensation.
Apr 01, 2014 | Admiral 26 cu. ft. Side-By-Side...
How to drop the front wheels on the refrigerator
You should be able to remove the plastic grill at the front bottom of the frig exposing the leveling screws which you can adjust without moving the frig.
Oct 13, 2013 | Liebherr CS2062 Bottom Freezer French Door...
My maytag refrigerator has wheels both back and front. The front wheels are bigger and the back wheels are smaller and they have screws holding them. The back of the refrigerator is a little lower than...
Look behind the grille in the front bottom of the fridge... there are adjusting bolts there to adjsut the height of the front and back wheels to level it...
heatman101
Aug 26, 2010 | Maytag MFD2560HES Bottom Freezer French...
Leaking from the front
I had same problem but different model #.
The part under the spray arm came lose and the gasket was hanging out. Causing it to squirt water right at the bottom of the door and leaking out. I took it apart put the gasket back in the groove, screwed it back down and is working great.
May 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Water dripping down the freezer & builds up on the bottom
  1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
  2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
  3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
Apr 17, 2010 | Kenmore Refrigerators
I have water in my refrigerator on the shelves and in some areas it is freezing?
Could be a clogged condensate drain. Since you did not give a model #, I will assume this has the freezer on top. When it goes into defrost, the water cannot go down the drain hose to the drain pan and accumulates as ice in the freezer, below the bottom liner and may drip into the fridge. Empty the freezer and open the fridge door. The open fridge door can help thaw the drain. Remove the screws holding the bottom of the freezer liner and remove the liner. If there is ice below it, the drain is clogged. Remove as much as possible by hand and then use a hair dryer to carefully melt the ice at the back of the freezer. Blot up any water from the melted ice and concentrate on clearing the 1/2" hole in the center back. That is the drain. When you think the drain is clear, check it with a large glass of hot water. This can be take some time. When done, reassemble, but also make sure the fridge is tilted to the back by adjusting the legs at the front bottom corners of the fridge. You may have to take the grill off the bottom of the fridge to do this. The legs screw down to lengthen them. Adjust them far enough down that the fridge door swings shut by itself. This will help the water down the drain before the fridge comes out of defrost, starts cooling and freezes it in the drain hose.
Mar 03, 2010 | Whirlpool Refrigerators
Our GE upright freezer door keeps opening on its own! Our food is starting to melt and the manual only talks about tightening the refrigerator door. What should i do?
Your refrigerator is leaning forward to far and you need to adjust the front legs so that it is slightly leaning back. This is why the doors are opening as they work by gravity. On the bottom left and right front corners of your refrigerator you should round pads with threaded legs screwed it the bottom of your refrigerator. You need to lean the unit back and adjust these out to raise the front of your refrigerator until the doors when opened will slowly shut on its own. A level comes in handy for leveling also.
Oct 09, 2009 | GE Refrigerators
Water leaking from the left lower corner of the freezer
there is a drain at the bottom of the evaporator in the freezer section which is blocked,pour some hot water into the drain and that may unblock it
Jun 07, 2009 | Frigidaire FRS26ZSG
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
44 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
