Question about Sony Televison & Video
Sony KDS-50A2000 T.V won't turn on, power light flashes red 4 times.
  • 10,594 Answers
4 times error shows that any fan is not working as TV has 4 fans inside. You need to check what fan is not working.
Posted on Jun 15, 2009
How to get a picture on sony FULL HD 1080
Hi. Not shore of this model but could be a bulb replacement is needed, Or one of the filter covers may not be making contact.
The red light is indicative of error rather than working ( green ) or standby ( orange ).
I hope you get it sorted.
Sep 12, 2014 | Sony XL5200 LAMP - TV KDS-50A2000,...
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
I have a Sony KDS-50A2000 and when I try to power it on, the green light flashes like normal and then without the screen ever lighting up, the power light flashes red 9 times, then pauses and repeats this...
Now that you have the blink code, Google your make and model with blink codes added to the end. This will show you links to sites that will tell you what the nine blinks mean.
Sep 17, 2011 | Sony KDS-50A2000 50" HDTV
I have KDS-50A2000 Sony SXRD Projection TV. Serial #9028985. It was working fine then a few days ago I went to turn it on and the red power light was blinking 4 times and repeat... I then opened the lamp...
hello, this can cause the red power light to flash 3 time also if the lamp cover is not fitted securely this can also cause the light to flash 3 times 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped hope it helps
regards
shaun
Jan 03, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Will not come on. red light flashes 4 times
Never a good sign when you have red flashing codes
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Please rate my help++++Thanks for using FIXYA
May 28, 2010 | Sony KDS-50A2000 50" HDTV
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
My tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
Jan 02, 2009 | Sony KDS-50A2000 50" HDTV
Televison & Video Logo
182 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
