Question about Garden
Motor is loose. how is it bolted down
What tightens it up
  • 151 Answers
3-4 bolts, usually threaded from the bottom into the engine.
Posted on Apr 01, 2014
The belt is slipping
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Apr 29, 2010 | Dmm Vision Fitness T9500 Treadmill
Tip
When the walking belt is slipping during use.
on May 01, 2010 | Exercise & Fitness
Belt is slipping
Apr 03, 2010 | Cadence Exercise & Fitness
Belt is slipping
Mar 29, 2010 | RTO Image 15.0R Treadmill Walking Belt
The belt is slipping and making a squealing sound
May 14, 2009 | Proform Crosswalk 500 Treadmill
Belt is slipping on healthrider treadmill
Apr 30, 2009 | Icon Exercise & Fitness
It will speed up and slow down
This is caused by one of four problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. The fourth problem is that the lower board either needs to be adjusted or is going bad, I cannot be for sure without knowing the brand and model. Let me know if you have any questions.
Apr 20, 2009 | Exercise & Fitness
Belt & motor stops
Apr 14, 2009 | Exercise & Fitness
Motor is running but belt isnt moving
Mar 31, 2009 | Proform 650 Crosstrainer Treadmill
Belt slipping on treadmill
Jan 06, 2009 | Exercise & Fitness
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
