Question about ASUS Q200e Touchscreen Notebook
Won't Charge So the other day my charger crapped out on me and I had to order a new one. In the meantime my battery on my Notebook completely died. It has been dead for about 2 days. Today my new charger arrived and I plugged my laptop in. The orange charging light is lit, however it has been plugged in for about an hour and whenever I try and turn on the laptop, it just dies again. Before this the computer was booted up and working fine for about 5 or so minutes and then died. Now it wont stay on past the loading screen. Am I just being impatient or is there something to really worry about??? P.S. This laptop is only about 8 months old.
  • 151 Answers
If it's not a recognized charger it'll stop charging the battery and try to run on the charger alone. If the peak draw of the laptop is higher than the charger output, it'll go right back off.
Try removing the battery and see if it'll boot on the charger alone.
Posted on Apr 01, 2014
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Posted on Jul 19, 2009
  • 20 Answers
SOURCE: asus 1005ha netbook wont turn on
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena95
Posted on Jan 03, 2010
  • 19 Answers
SOURCE: my Asus S6F laptop battery wont charge it sits on ...
1)Reason:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
2)Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
come from laptop battery site:http://www.buy-battery.ca/faq.htm
Posted on May 27, 2010
  • 212 Answers
SOURCE: my asus notebook won't charge i
if it wont charge it most likely has a bad battery...if you just bought it, I would suggest returning it for a replacement. Make the vendor or manufacturer make good on their product.
Posted on May 12, 2011
SOURCE: my asus eee pc 1000HE has the orange charge light blinking and says it's charging, but i've had it plugged in for days and it wont charge
your battery might be dead. just replace your battery.
Posted on Feb 17, 2012
Dell precision m6300 battery won't charge.
You say it's a new battery. Is the battery the same EXACT spec? Some aftermarket batteries don't work well with your laptop. The pin-out/connections may be incompatible. That said, in your BIOS is there a "Battery Learning" section.
Jan 04, 2013 | Dell Precision M6300 Mobile Notebook
WORX 24V charger won't charge
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
Aug 26, 2012 | Worx 24-volt Cordless Electric Lithium-ion...
Works when connected to charger but no power from battery changed battery still the same
if you disconnect the charger and the battery died then that means that your laptop battery is broken and it won't work untill you get a new one.
Apr 10, 2012 | Panasonic Toughbook CF-27 Notebook
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
Walkie talkie batteries don't last
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Charging new battery
usually 8 hours.
for first charge.
on a brand new battery
Jan 29, 2009 | IBM ThinkPad T41 Notebook
ASUS Q200e Touchscreen Notebook Logo
153 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
