Question about Motorola Mobility Motosmart Flip XT611 Unlocked Quadband Android Flip Phone
Flip phone screen is white and dot is red
Screen goes white
  • Official Brand Answer
  • 1,623 Answers
Phone has water damage and needs to be replaced.
Mark
Motorola Support
Posted on Apr 25, 2015
4 Suggested Answers
Bajanguru
  • 7752 Answers
SOURCE: screen gets distorted and turns white
the flexcable need to be replace on the phone
Posted on Jun 08, 2008
  • 26 Answers
SOURCE: When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Posted on Nov 26, 2009
tickets1
  • 641 Answers
SOURCE: I have a motorola razr 2 and it has water damage
take the battery out and put in in a sealed bag of rice..this isnt a joke..the rice will absorb moister and possably ,youll be ok..
Posted on Mar 11, 2010
White screen
did you drop it in water, ?did you press the screen to hard and cracked the lcd panel? those are the most common reasons, oh, and dropping it, and also dropping it in water. I would suggest going over all those possibilities.. open up the back of your phone and pull out the battery, in all phones now they have a water sensor dot, it remains white always unless the phone was damaged by water, and warranty doesnt cover water damage, look for that little white dot, if its red, that means you gotta get a new phone, and if you try peeling if off theyll know youre covering up water damage, unless you were able to somehow obtain another white color changing dot to put back in your phone now in the exact place it should be, but techs are very good at catching bluffs. but if that white is intact to begin with, your phone should be under warrenty of some sort, and that means they owe you a new one. bottom line. BOOM
Sep 20, 2012 | Motorola Mobility MOTO W755 Cellular Phone
Red dots on screen
Look for any loose contacts in RC jack, cable, connectors. Try using a different input device.
Aug 13, 2012 | Samsung PN51D550 51 3D HDTV Plasma TV
Why does my phone screen stay white?
it will be alright after 30 days. Be calm and quiet.
Aug 11, 2012 | Samsung C3050 Cell Phone
Can i stop the alcatel one touch 665 from playing a tone when i open and close the clamshell
Goto Menu then Profiles you see a red dot on General. Press options on lower left of screen and Edit. scroll down to Flip Beep and click it then scroll to Silence and press Select on lower left of screen. It worked for me.
Nov 20, 2011 | Cell Phones
What would be the right wiring on a cvr 12 to 4 ohms i am running a hifonics 2000 class D thanx for the help
Assuming that you have a 4 Ohm Dual Voice Coil (DVC) sub, you should wire it in parallel for more output. Solid red connects to red with white dot, and goes from solid red to amp positive (+). Solid black connects to black with white dot, and goes from white dot to amp negative (-). For a good diagram, go to this link: http://kicker.com/dvc_wiring
Apr 25, 2010 | Jl Audio CVR12 Kicker 12" CompVR Series...
My Nokia 3220 is continuously buzzing when I inserted the battery. Set was sank in a bathtub and soaked.
remove the battery and flip the phone upside down to air dry. Check where the battery goes to see if it was water damanged by the white dot being pink.
Sep 26, 2009 | Nokia 3220
Screen goes white
if you take the battery cover off is there a red dot inside beside the bottom of the battery? It may have had some liquid damage or the display chips inside may have bad solder connections... Let me know if i can be of any help!
Sep 03, 2008 | Motorola Mobility RAZR V3
Screen gets distorted and turns white
Jun 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Phone will not turn on
ok, take out the battery and look and see you can see a white dot pice of circular paper, if it is red, your phone somehow got water in it, look at your battery(white dot paper) if it is red than you have water in you phone. now you need to dry it! leave it on your car dast board in the sun 24hrs or use a hair dryer ( use low heat) you must dry your phone and battery completely before the next step, Next step- find a good working battery and insert it in your phone, see if this will correct your problem, sometime the battery volt are very low or maybe the battery itself its bad, but make sure you put in a new battery to test this out, don't pay for the battery until you check you phone at the counter, ask for the right model for you phone.
good luck
z
Nov 30, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Blank screen
sound like a problem with the flex ribbon connection.
when your openning the slide it may be dislodging it slightly
Nov 08, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Motorola Mobility Motosmart Flip XT611 Unlocked Quadband Android Flip Phone Logo
70 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
