Question about Penn Gt Series Levelwind Reels 330GTi
How to switch hand cranks from right to left on penn silverado 5000
Can't figure out how to switch the hand crank from right handed to left
3 Suggested Answers
  • 2976 Answers
SOURCE: Penn 113 senator
If ythere is a screw directly across from the crank, remove the screw and insert the crank from that side
Posted on Feb 20, 2009
SOURCE: How do I take apart the crank side of a Penn 209?
The star drag wheel unscrewed, just had to us a little force.
Posted on Sep 12, 2009
I have a Bulls PRO M6.0 bike and I can't remove the plastic cap on the crank side of the bottom bracket to get the cartridge out. How do I remove it? I assume it is left hand thread.
No specs available on bike, and you do not say what type BB, so very hard to advise. Also, your use of the word "cap" is confusing. There is a dust cap on most cranks that has to be removed to access the bolt that holds the crank on the spindle. If that is what you mean it is a regular right-hand thread.
If you actually mean the part of the BB that inserts into the frame (the ring/cup) then that is a left-hand thread, but the left (non-crank) side has to be removed first, and you may need a fairly long wrench to break the seal on the right side.
Apr 08, 2017 | Cycling
Is the crank shaft pulley on a renault 1.5 megane left/ or right hand thread
They'd be right hand threads-regular threads-to loosen, turn counter clockwise. An air impact wrench is best for removing the crank bolt. Or a long breaker bar and socket on the bolt, if you can hold the crankshaft stable so it doesn't turn backward with pressure on the bolt. You can pull the starter off, and wedge a big screwdriver or prybar against the flywheel's ring gear teeth, then turn the bolt with the breaker bar.
Jul 13, 2012 | Renault Megane Cars & Trucks
Is YZ 125 Clutch hub nut left or right hand thread
I don't Know, but the nut will be set to tighten when the crank turns. So just check which way the crank rotates while running and loosen in the Same direction.
Feb 12, 2012 | 2003 Yamaha YZ 125
The pedal assembly on my blackwater somehow got stripped always had problem with pedals coming off
If the thread on the crank arms that hold the pedals are stripped, you will need a new set of cranks. That is definitely a job for the bike shop. Make sure the pedals are snug in the arm, Right side pedal has right-hand thread, left side (looking down when you are on the bike) has a left-hand (reverse!) thread.
Jul 10, 2011 | Huffy Blackwater Men's 26-Inch Mountain...
I need a serpentine belt diagram for a 1993 ford 7.3 idi diesel
ok very simple! start from the crank! left hand and right hand! go around that crank! right hand go up then around the water pump! then follow around the power steering pump! then along side the vavuum pump !the over to the pass side!under the idler pulley to the alternater!down to the tesioner!
Apr 28, 2010 | 1993 Ford F350
Removeing the bolt from the crank pully
right put the starter motor back in,then re connect .put the right size socket on the pulley bolt and use a long snap on bar jammed into the suspension then crank the engine with the starter motor and it will undo itself ,dont forget to put some contact sdhesive back on the pulley bolt thread when rebuilding
Apr 12, 2010 | 1997 Volkswagen Jetta
Crank shaft pulley
Should be a right hand thread . Only left hand threads I have come across are Honda's and some Mitsubishi's.
It will be very tight!
Hope this helps
Aug 01, 2009 | 1995 Isuzu Rodeo
Crank shaft bolt left or right hand thread on rav4
It's right hand thread, but very tight. One trick mechanics use, is to disable the igniton, and put a johnson bar on it, with it braced somewhere against a frame member, and crank the engine very briefly with the starter. The engine cranks clockwise so you must ready the bar against something in that direction. As you crank, the bolt resists in the counterclockwise direction and comes free. Sometimes makes a bit of noise, but it works like a charm.
Mar 11, 2009 | 1996 Toyota RAV4
Penn 113 senator
Feb 10, 2009 | Penn Gt Series Levelwind Reels 330GTi
Penn Gt Series Levelwind Reels 330GTi Logo
22 people viewed this question
Top Penn Sport & Outdoor - Others Experts
Mike Marcotte
Mike Marcotte
raysaw
Tom Chichester
Are you a Penn Sport and Outdoor - Other Expert? Answer questions, earn points and help others
