Question about Vinotheque Whisperkool 4200 Wine Cooling Unit (Max Room Size = 1000 cu ft)
WhisperKool 8000 cools nicely but when the unit hits set temperature, the fans on the front of the unit stop but the compressor and back fans continue running. UNit eventually starts to freeze over.
Unit has had Freon added recently; New thermostat purchased two years ago
3 Suggested Answers
SOURCE: The Whisperkool 4200 unit is no longer cooling the
Version:1.0 StartHTML:0000000149 EndHTML:0000001329 StartFragment:0000000199 EndFragment:0000001295 StartSelection:0000000199 EndSelection:0000001295 All WhisperKOOL units come with a 2 year parts and labor warranty with a 5 year warranty on the compressor. During the warranty period, if the unit fails a replacement unit is sent at no cost to you. If your unit fails after this period we offer a Consumer Care Program to give the customer a chance to get a new unit at a deep discount. In many cases, the failing unit has been misapplied and the correct unit for the installation is sought after during the replacement process. Our customer service department is trained extensively, with live customer service representation with a streamlined process for not only helping with the products, but also assisting in identifying any limitations to the installation or ventilation of the cooling unit.
If a repairing the unit is the decided route, call WhisperKOOL directly at 1-800-343-9463 and parts can be ordered depending on availability. A knowledgeable HVAC Professional should perform any repairs due to the refrigeration system.
Posted on Jul 09, 2010
SOURCE: Whisperkool 4200 icing up
Hi, Bob:
Misery loves company, so I'm posting this even if it isn't in time to help you.
I had an XLT 8000 with similar problems. Vinotheque wanted to do the exchange program ($2,500+), and I was told the older aluminum coils might have leaked, and the exchange models come w/ SS coils. I was near to biting on that, when I decided to have a local refrigeration shop check it out.
Here's what they found--A MANUFACTURING DEFECT. It seems there are small copper capillary tubes that circulate the refrigerant. If they touch each other, with normal operating vibration they can wear holes in each other and the refrigerant can leak out. The leak can be very slow. According to the guy who fixed it (all for $219, and much of that was for drilling out the riveted-closed enclosure), "crossed cap tubes" is a Bush League mistake, akin to not putting oil in your car's crankcase.
I'm not saying WhisperKOOL/Vinotheque did this on purpose, knowing there would be an eventual failure and an opportunity to make another sale. But what the service guy told me was that IF the manufacturer was without scruples, a crossed cap tube would be the perfect way to take advantage of an unsuspecting customer.
My fix? Drill out the rivets, and find a local qualified service tech. Fixed in hours for $219 or in weeks with an exchange for $2,500... You choose.
Posted on Jul 14, 2010
Portable A/C: Compressor runs intermittently and doesn't cool room
Your issue sounds like either a bad "pressure switch" or that the unit is low on "Freon." Either of these problems will cause the compressor to start and run shortly then compressor cuts off, then and repeats itself.
From your description It really does Not seem to be a "bad board in that unit" because the compressor is starting up, even though the compressor is not staying on long enough to cool said area.
Aug 15, 2016 | Heating & Cooling
Hi i have a wirlpool fridge the freezer and fridge works fine but it seems the motor keep on running and dont switch off or is it the fan that is running please help
Hello Sandra;
My name is Peter. I am a retired field service refrigeration technician.
You just have a simple operational and maintenance issue.
Neither your compressor or fans should run continuously.
First, you need to clean your condensing coil. You did not provide a model number so you either have a flat cooling coil in the front bottom, or a canister type in the back right hand side. This coil dissipates the heat. If it is plugged up your compressor and fans will run trying to keep up with the unit temperature settings. This can make a difference as much as 40 degrees. The toe plate, bottom front is either held in place with a screw on each end. If no screws, there is a clip on each end. Just pull and it will pop out.
Second, You only have only one cooling source and that is your freezer. The freezer will try to satisfy itself first before the fresh food section. If you set the temperature controls beyond the unit design settings your compressor and fans will keep running. Set your freezer to -2 or +2 Deg. F., and set your fresh food section to 35-40 Deg. F.
Third, Check your door gaskets. make sure there are no gaps.
Dec 21, 2014 | Whirlpool Replacement Refrigerator...
Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
Download this illustration and then using a good multimeter start basic troubleshooting.
All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
If the compressor fails to start or the fan you may need to replace the capacitor.
You may need a hard start kit.
Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
The Whisperkool 4200 unit is no longer cooling the wine room. The digital display is jumbled and will not reset when unplugged. The fan runs constantly but the wine room is only be cooled to 64 degrees. I...
Jun 30, 2010 | Vinotheque Whisperkool 4200 Wine Cooling...
Hi, Bob:
Sep 25, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
What type of electrical plug is used on the Whispercool 8000 or does it come ith wires that need to be "hard wired' into a box. Thanks, Ed
Thought by now you would already have the information. Electrical Requirements 110v, 20 amp dedicated circuit Below is a link to the user manual and page 14 addresses your question on electrical requirements.
Click Here=> http://vinotheque.com/docs/WK_Extreme_OM_070607.pdf
Home page below.
http://www.wineracksamerica.com/Wine_Cooling_Units/Whisperkool/extreme/ES8000.html
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 21, 2009 | Vinotheque Whisperkool 8000 Wine Cooling...
LG 24000btu not blowing cold air. Fan runs but i do not hear the compressor kick on. temps upstairs hit 104 and temp is set at 80. unit is only in use for 2 months. none stop though on cool.
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Sep 04, 2009 | LG Electronic Window Air Conditioner
Cool air outlets frozen over with ice
And the temperature hasn't changed at all (still set at 55ºF)? A troubleshooting guide says you can check if the cause is because too much heat was lost to adjacent areas, and you can try to add more insulation around the ductwork and ensure doorways and glass panels are sealed. Other than that... not sure. If it's older, maybe you can look into a new Whisperkool split system or cooling system (there's some great ones on http://www.vintagecellars.com).
Jan 02, 2009 | Vinotheque Whisperkool 3000 Wine Cooling...
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Furniture Logo
32 people viewed this question
Top Vinotheque Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Vinotheque Furniture Expert? Answer questions, earn points and help others
