Question about magicJack pc to phone, free local & long distance calling, magic jack voip phone
I can't get a dial tone on my magic jack phone line.
I can't get a dial tone on my magic jack phone.
  • 151 Answers
If restarting doesn't work or the solutions on the web site, you likely need the unit replaced. Personally I like the plus better because it can plug right into the network, account can be transferred. Caution, it likes to run hot when used on network and will need a cool place.
Posted on Apr 02, 2014
Why dont I have a dial tone, phone does not work . no ring cant answer when people call
if you have no dial tone , you have no line to the exchange
it can be from the call cancel switch ( hang up button) or an extension that is not hung up properly
It could be an external problem so you will have to get the service provider to check the line from the building out
As that may require you to pay if it is not faulty, try borrowing a phone and plugging it into the wall socket for the phone
If you get a dial tone on the borrowed phone , it is your phone but if there is still no dial tone , it very well could be a service provider problem
Dec 30, 2015 | magicJack Two, 2 Magic Jack Plus Voip...
Why does a CS6124 not work with Magic Jack?
that phone should work with magicjack , you are not getting a dial tone because you are no setting it up right somewhere along the line ,
Dec 10, 2014 | VTech Communications Cs6124 Cordless Phone...
Magic jack customer service
You need to contact Magic Jack.
Aug 16, 2014 | Lands Phones
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    When I try to send a fax on my lexmark x4650 it has error no dial tone?
    If you are getting "no dial tone" as an error on your fax machine, it means that you have the telephone cord plugged into the wrong port on it.
    Turn the printer around so that you can see the back of it. If you look closely, there should be three ports to choose from in which you connect a telephone cord. Sometimes they put a little white plastic piece in the ports to keep them clean during shipping ect. If this is the case, go ahead and remove them now.
    If you look closely at each port , you might notice that they have text or pictures right above or below them to tell you which one to use. let me explain; if you have one telephone line and wish to use it for both fax and voice calls - you will need more than one port. That's why they mark them.
    One of the ports should say "line" or have a picture with a funny little symbol on it. This is the port that you would use if you want to fax someone using your printer. You plug your phone cord into this port on your printer.
    One of the ports should say "phone" or have a picture of a telephone by it. This port is used when you want to share a single phone line with both your fax machine and telephone used for making voice calls. To split your line between both fax and phone, you plug your phone cord from the wall into the port marked "line" and take a second phone cord and plug it into the port on your printer marked "phone" and the other end of that line goes into your telephone (voice line).
    The last port should say "line 2" or similar and usually has no picture next to it. This is an additonal port to share with a second phone line.
    To correct your problem of "no dial tone", plug your phone cord into the socket on the wall and put the other end into the port on the printer that says "line". Now lets test the connection.
    Put a piece of paper into your printer, press the fax button and dial any phone number using 1 and then the area code followed by the phone number and press 'start" or "ok" to begin the fax. If you have chosen the right port to connect your telephone cord, you will hear a dial tone first, and then dialing of the numbers you chose. If you cannot hear a dial tone before your numbers begin, then you have not chosen the right port. If this is the case, remove the phone cord from the port you have chosen and try another until you do hear the dial tone.
    NOTE:
    Do not try to go from your phone jack into your telephone and then use a second port on your telephone to connect a second phone cord that is plugged into your printer/fax. A second phone port on your telephone is most likely for a second phone line to use for voice calls. The majority of phones for residential use do not have a built in splitter that works like a fax/printer does. If you try to use a second port on your phone to split to your fax machine, it usually will not work. Follow the instructions as listed above to re-route your line and correct the problem.
    MAGIC JACK USERS:
    While magic jack is great for making free long distance calls, it is not suggested for use with a fax machine. if your trying to use your magic jack phone line to fax it usually does not work.
    Jul 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
    Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
    There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
    Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
    Aug 31, 2009 | Panasonic Lands Phones
    magicJack pc to phone, free local & long distance calling, magic jack voip phone Logo
    111 people viewed this question
    Top magicJack Computers & Internet Experts
     Russ Hill
    Russ Hill
    David Payne
    David Payne
    Andrew Taylor
    Andrew Taylor
    Are you a magicJack Computer and Internet Expert? Answer questions, earn points and help others
