Question about Kenmore Air Purifiers
Kenmore 85500 air purifier stopped working
Stopped working. May need resetting, but not sure how.
  • 151 Answers
Remove and replace guard over filter, the switch gets sticky.
Posted on Apr 02, 2014
3 Suggested Answers
SOURCE: csonka ozone air purifier super
It suddenly started running, and I have no idea why! ! You guys scared it into behaving itself, I guess.
Posted on Sep 28, 2008
SOURCE: kenmore air purifier- model 85500
Power Off the unit then Press and HOLD the Off-Timer and Function buttons at the same time WHILE Powering the unit back On. The Replace Filter light will blink for 5 seconds than go out. Now you can release the the buttons.
Just to make sure everything is working fine power off and on the unit.
On a side note if you are a tight wad like me you may want to just smak the filter layers against the ground a few times to clean them and re-use them / make them last longer. When the replace fileter light comes on too often then it is time to replace the filter.
No worries ;o)
CDA
Posted on Nov 16, 2008
Overheated motor will not reset
It may take a while to cool and reset. If ity has been over an hour the thermal switch could be faulty.
Hoover WindTunnel WindTunnel vacuum cleaner Owner Manual Thermal Protector
Jul 13, 2016 | Hoover Vacuum Cleaner - Wind Tunnel
Where can I find replacement filter for Kenmore 85500 air cleaner
I just went to the chat site for sears parts and asked them to find one. They ordered part #119010 Filter CATEGORY: Plumbing and Heating
PART NUMBER: 119010
which comes up to this page... http://www.searspartsdirect.com/partsdirect/part-number/119010..... I did order it through them.. I hope this helps anyone else looking for a replacement filter for the Kenmore #85500 with filter #85501.. With the link above you can order it online.
Feb 14, 2013 | Kenmore EnviroSense 85501 Air Purifier
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
Aug 07, 2012 | Honeywell 50250-S True HEPA Air Purifier
My Ionic Breeze Model S1637 just stopped working and I don't know what to do. Is there a solution for this. It appears as if the unit is not getting any power?
Test the outlet that it's plugged into, to make sure it's still functioning properly. There may be a loose connection at the receptacle or the circuit breaker in your home's circuit breaker panel, for that receptacle may have been tripped. If it is, before resetting it, make sure the air purifier is not plugged in to it. Then plug the unit in and turn it ON. If the circuit breaker trips again, there's a wiring short in the air purifier. Contact Sharper Image for possible repair or replacement.
Apr 04, 2011 | Sharper Image Ionic Breeze 3.0 Air...
The fan stopped working on our Living air classic XL15 so we just changed the motor. The machine comes on but the fan doesn't. Is there a reset button that needs to be reset? Or something else to do?
Sometimes you have to give the fan a push with your finger. If that didn't work, check all connections, fuses, etc. Sometimes things get jarred. If you changed out the connections at the ends of the wires (they include new ones with the replacement motors) you may need to make sure that you connected and/or crimped them correctly.
Jan 21, 2011 | Ecoquest Living Air Classic Air Purifier
Manual
no just a switch on cover that has to be pushed in by the cover before it will be safe to turn on
Apr 04, 2010 | Brookstone Pure-Ion UV Air Purifier
All of a sudden it just stopped working. nothing lights up .
Check your fuse and cord. make sure the outlet works where it is plugged up to.
Mar 03, 2010 | Ecoquest Breeze AT Living Air Purifier
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Air Purifiers Logo
233 people viewed this question
Top Kenmore Air Purifiers Experts
fordexpert
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
