Question about Eyemax DVST GN-704JLC] Mobile DVR System. 4CH Records on Compact Flash CF Card
How do i save recordings to the CF card to look at later from a PC?
Just bought this mobile dvr with a 32 gb CF card and in the vehicle it records and saves events just fine but when i stop the recording and bring the card in to check it out on my pc, it says its empty -put the card back in the dvr and its blank. It's not writing to the cf card.
DVR Cplete Hung & freez
sounds like a software problem. could be on Windows or on the NVR software. best bet is to re-install windows formatting the hdd completely. once done re-install the NVR software. if that does not solve your problem have a look at the graphics cards in the unit as well as the hdd. they could be faulty.
Dec 09, 2013 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Records only 7 - 9 second :--(
check the sd card on your pc/laptop make sure its in fat32 format. check record settings, on record setting (4gb and above) set it to intervals of 15min. and save setting. sd cards over 8gb are prone to over heat or not record over as it needs to be able to record over older files. 32gb type you need a high end sd card for them to last the better the quality of sd card the better they last. you can also get a corrupted data file either on the video of the format. either way the ds card will need formatting again. hope this helps.
Aug 17, 2013 | everbuying GS8000L Full HD 1080P 2.7 Inch...
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
What do i need to connect my canon zr500 camcorder to my pc?
IF, your camcorder has FIREWIRE, than you can use that, and suitable DVR software. IF not, then I always recommend that, one use a TV/Video "Capture" card or USB "Dongle", either way, you simply connect that up, via, the AV, leads, usually S-VHS, or Composite, Or Component, or Firewire, Use a DVR, and basically, "Play" the "Video" and "Record" on the PC, with Digital Video Recorder, DVR, and save as a "Digital Format" then you can do whatever you wish, after recording. You can get propretory software from the manufacturers website, and download, drivers, and software to do as you wish. I recommend a program called Dscaler, it is the BEST DVR there is.
Apr 28, 2010 | Canon ZR500 Mini DV Digital Camcorder
How do I transfer recorded programs from my 622 DVR to my home computer?
http://www.dishnetwork.com/downloads/user-guides/receivers/622_UserGuide.pdf
User guide. above.
You would have to connect up, using a PC & DVR software and some form of TV/Video recording Card, or USB device. Then connect up via AV, Composite, Yellow, Video. White & Red Audio. and "Capture" either live video & Audio, so basically whatever was viewed on the screen, would be "Recorded" on the PC, via the TV/Video interface device, if using a laptop, then a USB "Dongle" & software would be the best. In a Desktop, a PCI-I card would be Best, Then using the Software that comes with the devices, you "Record" with that and "Play" with the Dish DVR, and save, the Streamed Video & Audio to the PC. Now, If you have Component Out, on the Dish, then this is the one to use, If you choose this way, remember the Device you are going to use Must have a Component INPUT as well, as A Stereo Audio Input, so ensure the device you get has that feature.
Mar 30, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Transferring songs onto new CF card
You'll have to create backups of your songs and transfer those backups using USB to your PC. Then with the 8 GB card inserted you can reimport them to the Tascam (USB) and restore them to the current working song which will then get saved on your 8 GB card. Do this for each song and then you can discard (delete) those backed up song files while connected to the PC.
Hope this helps.
bd.
Feb 07, 2009 | Tascam 2488 Portastudio Multitrack...
Is there a way to get the files off my Olympus VN-1000 recorder onto my computer?
You could get a cable to connect from the headphone socket to the line in/mic on your computer and record the files like any other external audio device. Not perfect but it will work...
Oct 22, 2008 | Olympus VN-2100PC Digital Voice Recorder
Can't save video file on memory card
Dear Customer,
this will happens only when your card & fone system havent enough memory for running this software for recording so trry to enough memory in mobile 's software runing batter,
when you will do this also have some space as you video recording to your card than it will succesfully recorded,
SO do only enough memory on your mobile internal memory & also on your card,its not a major problem,
THNX
May 12, 2008 | Nokia 6120
Eyemax DVST GN-704JLC] Mobile DVR System. 4CH Records on Compact Flash CF Card Logo
Top Eyemax Cameras Experts
Are you an Eyemax Camera Expert? Answer questions, earn points and help others
