Question about HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 Printer needs service?
My two year old HP Photosmart D7160 Printer sat idle for about 1.5 years. Now I plug it in to my new MacBook and install the driver. All inks are full, but error message on the printer's small screen says "Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0306. Turn power off then on again."
I have powered down&up the printer several times, unplugged from MacBook and wall, replugged in. Nothing seems to work. I no longer have the printer documentation. Any ideas before I trash it? Afraid to invest money in servicing when I can buy new...
Thanks!
    President:
  • HP Master
  • 1,996 Answers
Hp has an excellent online support site, available here, or here, as well as a user forum with q& a from other users that might help with that error.
You might want to try the solution posted in this link. It appears to have worked for quite a few folks. Read through to the end before you try it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 15, 2009
Red ink doesn't print properly
it could be the print heads are clogged i had the same problem with a printer i had a few years back that wasn't used for a week i took it into a printer place near me paid 20 pounds had the printer serviced and it came back perfect
Feb 11, 2014 | HP Photosmart D7160 InkJet Printer
HP D7160 Caridge won't undock
First change the old head with the new box pack head if the problem persist then change carriage unit the problem will be clear.
Jan 01, 2013 | HP PHOTOSMARTD7160 Photosmart D7160 Q7046D...
I put 2 new printer cartridges in and got the effor Oxc18a0101. What should I do? My printer is an HP Photosmart D7160. I've looked at some solutions on line, but they refer to typing numbers,...
Hi Karen, This likely is either due to Bad/Expired Printhead or it could be defective printer ( hardware failure ). However you can give it a try. Follow the steps below and it should solve the problem, else we need to consider it could be defective Printhead or printer hardware failure.
The Photosmart D7160 does not has "*" and "#" because it is not a fax capable printer.
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
The error message 0xc18a0001 "Ink System has Failed" is now gone
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 17, 2011 | HP Photosmart D7160 InkJet Printer
HP d7160 won't print black, New cartridge. Goes through the motions - but nothing hits the paper. Colors print fine. What gives?
1. Turn printer off and disconnect the USB cable from the PC to printer
2. Uninstall the printer driver and software-->here's how.
Navigate here for printer driver and software .(Select your Operating System and click next)
Install the printer driver and software -->here's how
Feb 23, 2011 | HP Photosmart D7160 InkJet Printer
My printer is now 2 years old. Always done great, nothing happened. But now he can't get the A4-paper out of the tray. He trays to grab the paper, but it doens't work. Photo's out of the photo-tray is...
Looks like you have a paper jam problem.Pieces of paper are stuck in the roller.Go to Control Panel ->Printers and Fax -> Select you printer and click properties.You will find a Printer Maintainance Wizard,which will have a paper jam clearing wizard.Click this and your printer will work as good as new.
Thank You.
Feb 20, 2011 | HP Photosmart D7160 InkJet Printer
HP photosmart D7160, ink sys failuar error code:
Hi otissr
If you are lucky, the solution given by HP in the following link will help.
Hope you wouldn't require a service call.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01936219&cc=us&lc=en&dlc=en&product=1156652
Good luck
If my answer is helpful, please give a rating.
luciana44
Dec 28, 2009 | HP Photosmart D7160 InkJet Printer
I am going to buy a new computer today with Window 7. Do I need to do anything to make sure my HP Photosmart D7160 Ink Jet printer works?
Yah, go on support.hp.com and verify that it has a Windows 7 driver installation for it. Some printers from HP do not. Some have a driver that came with windows 7 for usb only, in which case you can hack it to add Standard TCP/IP port once it has been installed USB. Of course that might support ALL of the things that the printer can do.
Nov 28, 2009 | HP Photosmart D7160 InkJet Printer
Photosmart D7160 shows yellow empty even with NEW cartridge
Printhead problems are more common than perceived. Have you disconnected the power cord for the printer to flush the built-in board? Disconnect the printer USB cord as well. If this doesn't resolve the problem call for an RMA. Printheads are not inexpensive.
Jan 20, 2009 | HP Photosmart D7160 InkJet Printer
I have a HP Photosmart 7160 and a brand new Fujifilm digital camera. I took 4 pictures and tried to print photos. When I place the SD 4GB card in it reads "memory card error" on the printer. What do I do...
You are using a new camera with an old printer.
Check the following:
- Try using a 1 to 2 GB SD card. The printer may not be able to hande one this size.
- Try taking a photo, in a smaller resolution, and save as JPG.
- Try plugging in the camera to the printer and print from the camera.
And the best option, is to transfer your photos to your computer, and print from there.
Take a look at a program called "Thumbs Plus" it has worked well for me. http://www.cerious.com/
If you have lost your manual, see: www.HP.com/Support for other answers.
Jan 01, 2009 | HP Photosmart D7160 InkJet Printer
HP D7160
replace the carrage unit in the printer
May 26, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 InkJet Printer Logo
502 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
